Do I need a N20 converter?
Old May 29, 2003 | 05:05 PM
95 Mystic TA's Avatar
If I am planning to run a 100 shot of the gas, maybe once or twice a week at the most, do I need a N20 converter versus a 2800 stall that isn't built specifically for nitrous?
Old May 29, 2003 | 06:51 PM
funina91ss's Avatar
if you already have a 2,800 stall what brand is it? some of the other brands are already built to handle the shock off the line. If you have a stock stall you will most likely not have a problem untill you get into a larger shot. So in simple terms No you dont need a converter made for N20(unless spraying large amounts)
Old May 29, 2003 | 08:23 PM
Tofus 93Z28's Avatar
Lightbulb n20 convertor
not so much need, but want... a stock or poorly made convertor will not be as efficient compared to an aftermarket or higher quality unit.. i doubt you will grenade a stock convertor, your more likely to damage the transmission first, then the convertor.. depending on what breaks...
75 or 100 shot only..you will be fine with a 2800 or stock convertor...
Old May 29, 2003 | 09:22 PM
Thanks fellas. I currently have a stock stall in the car now but I'm not driving it because the trannys going out. I will be going with a 2800 with no more than a 100 shot.
95craz28
11
Sep 12, 2015 07:47 AM
USN06
Sep 7, 2015 03:30 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Cbr02
Aug 24, 2015 07:12 AM
Aug 5, 2015 08:35 AM
