96cam4ro
05-29-2003, 11:22 AM
1. Do I have dual cats or a single cat?
2. What headers are available for these cars? The cheaper the better.
3. What cat-back systems are available? I'm looking for a dynomax super turbo cat-back.
4. Are the underdrive pulley kits for TPI's the same as for TBI's?
Thanks.
91RS5speed
05-29-2003, 01:06 PM
All tbi cars got a small single cat.
alots of choices for headers get a set with a y-pipe so there is less fabwork slp and hooker are the best i think but they are going to be pricey i recomend getting the coating also.
the tpi catback will work, all will be about the same gains just make sure you get a 3 inch i
yes the tpi pullies will work on your tbi car.
96cam4ro
05-29-2003, 06:04 PM
Will that Random tech exaust fit on a TBI? I have had great experience with it on my 96..13.94 RWHP. Very quiet too..
Damon
05-29-2003, 07:07 PM
One thing you need to make a decision about with a TBI system is the exhaust diameter BEHIND the headers. If you buy a TBI-specific set of headers and y-pipe it will be essentially identical to the TPI system set EXCEPT that the collector pipe (y-pipe outlet) will be only 2-1/4"- same size as a stock TBI cat. Too small to make power. I highly recommend you buy everyting as if you were putting it on a single-cat TPI car of the same year. That will get you the larger 3" collector pipe (to take a larger 3" cat) and then you can put the larger 3" cat back on the car, again, as if it were a same-year TPI car.
All the hangers will line up just like stock except the cat, since you're buying an aftermarket one anyway. A muffler shop can take care of this minor difference for you fairly easily.
96cam4ro
05-30-2003, 01:47 AM
Do these things have rear O2 sensors like the OBD2 in my 96? I'd like to take off that old catalytic converter without having to buy O2 sims.
jstcrzyengh
05-30-2003, 01:57 AM
Dont use underdrive pulleys. Nothing but problems. Not worth the gain IMO
James
Beast5spdGTA
05-30-2003, 11:49 AM
No they only have 1 (one) single wire 02 sensor on the driver's side. They cost $18 from autozone.
