42# or 55#?
It's Cochese!
05-29-2003, 10:07 AM
Here's my proposed setup (I'm determining prices right now):
355 LT1 w/ Vortech S-trim (boost unknown) w/ Aquamist setup. Ported heads w/ intake, 67gph pump.
Some have said go 42#, some say go higher.
Also, I need to look for high-impedance, correct?
95 Silver TA
05-29-2003, 10:33 AM
How much power are you looking to put down?
I am using 50# MSD Injectors that bought from Combination Motorsports (they are flow tested too).
If you are not using and Impedence box, you will need the High Impedence Injectors which the 50# MSD are.
Hope that helps,
Claude
It's Cochese!
05-29-2003, 10:36 AM
Hoping for somewhere between 450 and 500 at the wheels (more would be ok, too).
Got a website for them?
94SLUG
05-29-2003, 10:42 AM
Im in that area with Ford Motorsports 42lbs. Just go to the vender list on the left side of the screen, there will be many places that have 42s or 50s.
95 Silver TA
05-29-2003, 11:17 AM
Here is a link:
http://www.cmotorsports.com
I have heard of a few folks going up as high as 600RWHP with the 50# injectors and a Good Fuel Pump.
Hope that helps,
Claude
It's Cochese!
05-29-2003, 01:06 PM
Geez $220 to upgrade to the 50#. I think I'll see if I can do with the 42#s.
MIGHTYMOUSE
05-29-2003, 02:48 PM
42's can make it to and over 600rwhp depending on what your bsfc is, but you really gotta start paying attention to them over 550rw with any set up.
stubbs
05-30-2003, 01:27 AM
I thought the stock computer would only run low impedence injectors, and highs required a stand alone FMU.
SloCal94
05-30-2003, 03:18 AM
Just received my 55# high impedience injectors from racetronics. Going to be running d1 at 15# and shooting for 600rwhp.
BruceVette
05-31-2003, 02:37 PM
[i] I thought the stock computer would only run low impedence injectors, and highs required a stand alone FMU
brook [/B]
The factory computer only run high Z injector, Max is 50s and now Racetronix just came out with a new high Z 55s injector that can be run with stock ecm. The low Z are 75s 83 so on, these low z injector are required the use of aftermarket computer to control it or the the converter box.
Bruce
93LT1 Conv w/ZF6
Blown D1-SC/N2O
ARE built 383ci/Stage II heads
