13's?????????(maybe)
street demon2k3
05-28-2003, 04:30 PM
i just got a cut out and i was wondering if my car can go into the high 13's with a 2.043 60ft. and balding BFG's??????
89'Formula
05-28-2003, 05:49 PM
The weather and the track prep will ulitmately decide but I would think with a good 60' you'll see high 13's...make sure you pump up those front tires...anything helps. Good luck!
MN1996Z28SS
05-28-2003, 06:10 PM
It is possible, my best e.t. is a 13.95 @ 98 so you have the m.p.h. to do it. My 60 foot on that run was 2.0 so a little more traction should get you there.
street demon2k3
05-30-2003, 11:29 AM
my best 60ft to date was a 2.043 with out the cutout and the stock BFG's. would the cutout create enough power to get off the line faster??
MN1996Z28SS
05-30-2003, 05:46 PM
It should be. If you can get to the track when it is a little cooler out that will help too; as heat and humidity will make you run a little slow. Also the lower the elevation the better.
