Need4SpeedB4C
05-28-2003, 12:05 PM
Hey anyone here swapped out an 96-97 LT1 intake, computer wireing harness, injectors..etc and put it on their 3rd gen engine?
-Mace
-Mace
TPI conversation to an LT1Need4SpeedB4C 05-28-2003, 12:05 PM Hey anyone here swapped out an 96-97 LT1 intake, computer wireing harness, injectors..etc and put it on their 3rd gen engine? -Mace Screamin95 05-28-2003, 02:13 PM you dont need the comp, wire harness, just the intake. check out www.lt1intake.com Need4SpeedB4C 05-28-2003, 09:55 PM Well, I was referring to take the intake. I know about that, even though I still haven't seen any dyno results or any other stories about it. I'm talking about everything though. Doesn't the L98 fire differantly than the Lt1? I just figured if I got the computer, wireing harness, fuel rail, injectors, and the intake from a 96-97 Camaro I could bolt everything on my L98, drop the TPI and I could also use the OBDII. -Mace Need4SpeedB4C 05-28-2003, 10:02 PM man...I just made myself look retarded...I said "TPI CONVERSATION" hehe...wooo...long day...Obviously, I meant conversion . -Mace Zepher 05-29-2003, 03:33 AM The hardest part would be figuring out how to convert the Dist signal into an opti signal for the PCM. I am not sure if you can run an Opti on a regular sbc and run an sbc waterpump and I am not sure if an LT1 waterpump with an electric pump will bolt to a regular sbc. I could have tried this at one time when I had a couple of 305's and LT1's in my garage, but now all I have are LT1 parts. | ||
