Cleaning out the apartment of car parts
JimMueller
05-26-2003, 08:55 PM
Cleaning out the apartment - yes, all of this is in an apartment. If you have or know someone looking for 4th-gen F-body parts, read on. Some items have applications outside of a 4th-gen F-body, though.
These are going in the trash the end of the week if nobody wants them. I'm not shipping anything but might be able to meet you somewhere in the Orlando area for delivery. All items are as-is and I take no responsibility for them. Unless specified otherwise, these items were either removed from a 1998 Z28 or were purchased for use with it, and are used. You're welcome to inspect anything on the list.
Section One is on the honor system - you probably only want something if it has value. So if you're interested, shoot me a private e-mail with what you think it's reasonably worth. Else I'll post when I've thrown it out and then send directions to the trash compactor :)
Section Two is for actual sale items.
Jim
Section I: Best Offer
- (1) Pair Michelin Pilot Sport 275/40/17 tires. Worn into the wear bars.
- McLeod clutch assy, w/ red pressure plate, steel flywheel & shims. Removed because it began to slip.
- 2001 Z06 clutch assy, w/ pressure plate and flywheel. Removed because it began to slip.
- BBK 80mm throttle body. Removed because the cam arm broke while driving. Arm is still broke and cam spring MIA. Gone
- Stock upper control arms
- Stock rear shocks.
- Stock camshaft
- Comp Cams 216/220 cam. Minor damage. Good doorstop or attitude adjuster.
- Stock pistons (6 - don't ask)
- Stock crankshaft. No damage, and a better attitude adjuster than the cam.
- Rev 1115 valvesprings. Shouldn't be re-used. Alternate application suggested...advanced Lawn Jarts??
- Stock tranny mount Possibly gone
- Stock torque arm mount
- (2) M6 slave cylinders. Both GM P/N 15046288 Possibly gone
- (2) Stock O2 sensors
- Stock ignition wires
- (1) Set NGK TR55 spark plugs
- Wolf Bra for LT1 TransAm's
- The Club. Red handle, never used. With keys.
- (1) Set Hawk HPS front brake pads, p/n HB249.F.575
- (1) partial set of same, missing 1 pad due to damage during removal.
- Prothane universal tranny mount. Removed due to vibration. P/N 7-1604. Gone
- SLP License plate frame, stickers, adhesive emblem & pin acquired at SLP Appreciation Day. Gone
- (1) Set stock LS1 rotors. Never warped, never turned.
- (1) Set PowerSlot rotors. Never warped, never turned. Worse condition than the stock rotors.
Section II: For Sale
(1) Addco 32mm front sway bar w/ brand new Prothane bushings $100 Possibly gone
(1) Addco 25mm rear sway bar w/ original Addco bushings $100 Possibly gone
(1) Set Hotchkis boxed, non-adjustable lower control arms w/ dual poly/graphite bushings. $80 Gone
(1) Set Hawk rear pads, P/N HB250.F.653. Removed prematurely. Still have 1/4-3/8" of pad remaining. $40
SFB767
05-26-2003, 09:27 PM
I'm interested in those, but I have a question first.
My SES light came on twice, and I had the parts store reset it, the code said running too rich banks 1 and 2, and I heard it might be the cats or O2 sensors. I know in FL they'll replace the cats free until 80K miles. Are the O2 sensors in the cats and do you think the dealership will replace the O2 sensors free?
I just haven't had time to go, that's why I ask.
JimMueller
05-26-2003, 09:34 PM
The O2 sensors are not physically attached to the catalytic converters. On a stock car, there is one O2 sensor before and after each catalytic converter. The one in front essentially tells the computer how much fuel to add/remove to maintain the optimum 14.7 air-fuel ratio. The one in the rear basically monitors whether or not the catalytic converters are physically present.
The O2's I have have different length harnesses. One is about a foot long, and the other perhaps 8" long. They don't have part numbers on them.
I don't know if the O2 sensors are part of the emissions warranty. I'd certainly confirm with a dealer. If you can get brand new O2 sensors for free, that's the best deal.
Whistler
05-26-2003, 09:40 PM
Youve got mail
JimMueller
05-26-2003, 09:59 PM
Whistler: Received, and replied.
got_hp?
05-27-2003, 09:58 AM
damn jim.........you slip a lot of clutches?!? haha
my stock clutch is going bad i think, but my car is just bolt ons.......im wondering if one of those would be good for me.
JimMueller
05-27-2003, 12:51 PM
Haven't had any clutch slip problems since I went with the SPEC stage II. Well, OK, I shattered the disc once...but is that really slip?:cool: I'm not sure if the McLeod adjustable did anything, but it's been reliable. I also stopped going to the dragstrip so I'm sure that's part of the equation.
The McLeod unit needs shims. I think it came with four, and I have three of those four. Not sure where the other one is hiding.
The Z06 unit might work with just a new disc.
MustangEater82
05-27-2003, 08:43 PM
Whoa! HOw much did you get for that crap?
My stuff is just sitting around my room collecting dust.
