basic 3rd gen advice
mikeV8
05-26-2003, 02:38 PM
Im looking forward to gettting a Iroc camaro and i don't know much about them yet. What are the basic power mods for a 3rd gen. I plan on getting an Iroc so can anyone give me some more general info on this car. But if there are any better years for your money (i dont have much) please let me know.
DarthIROC
05-26-2003, 05:02 PM
The newer the better. If you can get a 91-92 they run a little harder and have different GFX, so they look a little meaner too. But they didnt make IROCs those years just Z28s (as if it makes a difference). You will want to get a TPI model. If you can get a 350. In my opinion if you get a TPI 350 car, then add a stall convertor, stealth-ram, and exhaust you will give any LT1 a very hard time :cool:
doug791
05-26-2003, 05:30 PM
i find the 89 to be the golden year. its the newest year that has the stronger 9 bolt rear.
fyrhwk1
05-26-2003, 06:09 PM
Subframe connectors, every 3rd gen whether its a daily driver or a hardcore racer needs them, tightens up the whole feel of the car and gets rid of a bunch of possible rattles. After that a wonderbar (steering box brace) and LCAs will help you put the power down, even a stock 350 can flex the stock ****ty stamped pieces let alone an upgraded motor with a high stall converter. Do you want a manual or auto? if manual dont bother with building a T-5, you can get a T-56 crossmember shipped to you for under $200, the rest can be gotten from a junkyard, plus it'll hold all the power you want it to unless you're gettting crazy with it.
Rice Killer87
05-26-2003, 09:42 PM
1 of the best power adders for a 3rd gen is headers...about 15-20 HP over the stock exhaust manifolds.
Tbird232ci
05-26-2003, 10:12 PM
did they come with rear disks too?
BigCasino87GTA
05-27-2003, 10:06 AM
"did they come with rear disks too?"
yes
atlasengr
05-27-2003, 11:08 AM
Do not get a 305. Make sure whatever year you go with, get a 350 in it. That would make your options 87 or newer. Look for rear disk brakes, L98 on the option codes and and "8" on the vin not an "F", I think it's the 8th digit on the Vin. Also, the 5.7L markon the hood next to the hood hinge, not 5.0L. That's all, good luck getting one and if you want to make it scream off the bat, 100 shot will do just that!--No bull :D
IROC350
05-27-2003, 11:25 AM
they did not make irocs in 91-92. they came with 4 wheel discs and the 9 bolt rear. try to find one with a 3.45 gear or so, they are expensive!! headers will probably be your best mod for cheap. with all 3rd gen V8's, they tend to open 'em up a lot! the 350's did not come with standard tranny's so try and find one with a good 700R4 transmission. the t-tops will leak if you get one with t-tops, but those are always good to have:) SFC's are a must also!
StealthElephant
05-27-2003, 01:35 PM
don't you have to pull the motor to install headers?
87DJP2001
05-27-2003, 03:02 PM
No, you Do Not have to pull the motor to install headers. :rolleyes: Some brands are more of a bitch then others to install.;)
lordmetalz28
05-27-2003, 08:02 PM
personally i got a 305 and it moves like a mofo. defintley go with an exhaust a flowmaster is a great choice dynomax sucks and is very restrictive. some freebies to up your hp a bit but not major would be some k and n drop ins removing your baffles from your air box and also try by passing your tb coolant and getting some ac rapid fire plugs your car will move after this
TheGreatJ
05-27-2003, 10:06 PM
With the Hedman shorties I just put in, I had to jack the driver's side of the motor up an inch and a half, but once I did that they just dropped right in. I also noticed a SUBSTANTIAL power gain on my moderately-built 355 over stock L98 manifolds.
Get a 350TPI car, put headers, exhaust, and SFC's under it, then get into heavier mods (gears, convertor, intake tract etc.)
Dirt Reynolds
05-27-2003, 10:21 PM
Bingo.
1989 was the only year you could get the PBR single-piston caliper rear discs with the 9-bolt diff. It was also the last year for the 9-bolt, which is much stronger than the 10-bolt. The 9-bolt has a 7.75" ring gear vs. the 7.625" of the 90-92 cars and 4th gen cars. Earlier 3rd gen f-bods got a 7.5" ring gear 10 bolt. The other advantage of the Borg Warner 9-bolt is the fact they do not have c-clips.
J65 4-wheel discs were available in 90-92 but were the Delco Morraine calipers, not the huge PBR units.
1988-89 L98 TPI 350, and the TPI 305 (manual transmission only version) also got the biggest roller cams of the 3rd gen era; 207/213 @ .050". They are also MAF cars, so they respond to mods without custom prom burning (to a point at least.)
Look in the glove box for the option codes sticker. JG1 is the aluminum driveshaft option with you could also get in 1989 (mine has this option.)
Also in beginning in 1989 you could opt for option N10 - dual catalytic converters, which added another 10HP to the 305 TPI (manaul trans. version only) and the big-gun L98 350.
The GTA is the most expensive of the 3rd gen lineup. They came standard with a whole slew of goodies like WS6 suspension and a TPI engine. Be advised the 305 TPI engines with auto. transmissions have the smallest cam profiles (aka the dreaded 'peanut' cam) and consequently, the lowest power outputs of the Tuned Port engines.
Find an L98 car (350 TPI). They have a tremendous amount of torque, and are worth the search. I found a 1989 GTA Gunmetal Metallic on a corner car lot last year. I wasn't even looking for another car, but after checking out the option codes and seeing the car had all the good stuff (PBR brakes, alum. driveshaft, dual cats, L98, etc) I decided it might be a good idea to pick it up. I havent regretted it one iota. Great car, super seats (the GTA has incredible seats), steering wheel stereo controls, and after checking out online sources, I found out only 644 GTA's were made in 1989 in Gunmetal Metallic.
Bottom line is these are great cars for the bucks. They are also getting scarcer by the day. Good luck with the search.
doug791
05-27-2003, 10:53 PM
plus in 90 they started putting in air bags which is a great safety feature but sucks if you want to change the steering wheel. Massive fines if a copper notices
Nitromethane
05-27-2003, 11:15 PM
I'm running 13.88's naturally aspirated with 392ft lbs of rear wheel torque and 225rwhp, following specs:
Dacco Detroit 2500 stall torque converter (best thing in the world, I also had a B&M Tork Master 2400 when it ran 14.4's but blew transmission)
1.6 Roller Rockers
10.2:1 pistons (rebuilt the motor last year)
TB Airfoil
Underdrive Pulleys (Crank & Alternator)
Cheap crappy paper filters
Cut out air box n routed a/c duct from grille to air box
Lakewood LCA's
Polyurethane torque arm bushing
Removed all emissions equipment
3" Exhaust cut out
Rear disc posi
May have forgotten some things but oh well, went 12.88 with a 100 shot of n2o, so exactly 1.002 seconds off my n/a ET :D
I haven't installed the headers yet but they do wonders for throttle response, friend of mine commented on how smooth my off-idle accellaration is, whereas his car has headers, if u so much as tap the gas pedal the car jolts forward, very very responsive.
Don't waste your time with a 305, once you've had a 350, you won't want a 305 ever again so just start with the good motor. TPI's make torque, that's all I can say.
Have fun!
DarthIROC
05-27-2003, 11:32 PM
1.6 Roller Rockers
TB Airfoil
Lakewood LCA's
3" Exhaust cut out
Rear disc posi
Have fun!
Wow. I wonder what a stealth ram would do for your torque curve. The problem I found i had when I was TPI is I made impressive 1/8th times but cause TPI hits a brick wall at 4400-5000 rpm my 1/4s were always lame. What kind of 1/8th and 60s do you turn. ALso with nearly 400 lbs of torque what kinda traction do you get?
Greed4Speed
05-28-2003, 09:32 AM
Not true. Try the ultraflows. Flowmaster has nothing on them for low restriction and maintained velocity. You can look straigt through the muffler, can you on flows??? No.
Screamin95
05-28-2003, 04:15 PM
I say get an 89 TTA! One hella car!:bow: :bow:
