It's Cochese!
05-25-2003, 10:28 PM
Pics?
Who runs a FMIC?It's Cochese! 05-25-2003, 10:28 PM Pics? Tech 05-26-2003, 12:39 AM I assume you mean front mounted intercooler. You might want to spell that out in the subject. I relocated mine but don't have any pics on the web. It's Cochese! 05-26-2003, 01:39 AM Originally posted by Tech I assume you mean front mounted intercooler. You might want to spell that out in the subject. I relocated mine but don't have any pics on the web. I figured since it was the F/I forum it would be apparent. 95 Silver TA 05-26-2003, 06:03 PM You can see pics of my front mounted 2 core intercooler on my site (see sig). I did notice that the Intake temps dropped about 10 degrees with the IC mounted in the nose rather than under the car. Also I notice my Coolant temps went down about 5-7 degrees in summer months, I think when the IC was mounted under the car, it would not let all of the hot air escape from the radiator hence my coolant temps were higher than normal. The other plus side to this mod is that you get your ground clearance back too. Hope that helps, Claude | ||
