I went to the track friday night, 80 degrees give or take a bit and not sure what the humidity was. I just had 4.10's installed a few weeks ago and me and a friend installed my flp longtubes last weekend with a slp loudmouth dual dual. Anyway, my previous best was a 12.69@ 111 with only a lid and catback in January(55 degrees). Friday night was a different story....12.81@ 111.96. I knew the e.t. would not be there(heat) thought my trap speed would!!!
Am I wrong for thinking that?:confused:
94GrayV6
05-25-2003, 03:58 PM
You're telling us you trapped 111 with a lid only?!?!:shock: :think:
Yes, you should have trapped higher. But, the weather sounded ideal when you ran the car before. If you run the car in those conditions again, you should pick up another 2 mph or so...
I ran my car about a month ago to a 13.47@102.5. Then I got new wires, plugs, coil, and fixed an exhaust leak and could only manage a 13.77 @102.1. I wouldnt worry about it too much.
HeavyChevySS
05-26-2003, 09:18 AM
Sounds like you picked the right mods for the car and the times are "OK". Those original numbers seem high. When you ran those numbers, did you have 2 or 3 runs with the same results or was it a one time run? I feel it may have been a freak run.
the weather definately is a factor also.
I ran 2 more runs that night I ran the 12.69 and they were 12.78 and a 12.72.... I had the lid AND a bullet (dynomax) muffler after the Y pipe dumping infront of the passenger rear tire. I ran the 12.69 at a better track...prepped....the other night my best 60' was a 2.07 and when I ran the 12.69 i cut a 2.00 60'(stock F1's)
I feel a 12.30 is possible in some 50-60 degree weather.....Don't take this as being cocky but I think my car is strong from the factory (not a freak) I ran a 13.06 @108 bone stock down to the paper filter. My car is strong and I have some good driving skills. Again, Iam not being a ***** saying I can drive better than all!
Thanks for the replys!
IllusionalTA
05-27-2003, 03:46 AM
Try shifiting higher.. your powerband most likely moved up some.. and the weather def. made a diff. too
I have the rev limiter set at 6400 and my shift light @ 6200. Iam guessing Iam shifting @ 6300 or a touch over. I wouldn't mind a cam with the valve components so I could shift @ 6500 as long as I would pull some 11.'s:cool:
HeavyChevySS
05-29-2003, 08:45 PM
Sweet ! Ya wanna sell your car? ;) ;)
Tofus 93Z28
05-29-2003, 11:52 PM
weather hurt you...humidity can kill a nite at the track...especially on a NA motor
oh yeah.... LS1+4.10's+sticky tires= one of two things
1.at least 12's
2.a broken rearend...
i personally have seem more of the latter.....
get some good weather and stickys and you should be low 12s. with a 111-114 trap...
good luck next time
