my car is pissing me off!! please help
Old May 24, 2003 | 05:35 PM
JeremyKweens's Avatar
I recently replaced a burnt spark plug wire with an accel wire using the connection boots from the moroso wire. Now here is my problem...I have a miss in 3rd, 4th and 5th after 4500 rpm....what could this be??
coil? more burnt wires? bad plugs? maf? fuel? possible the opti...which has been replaced once and fixed once?
Old May 24, 2003 | 06:21 PM
'94 Bad A Z28's Avatar
Just a heads up, when the Opti starts to do, it'll miss high end...
On another note, a cheaper solution would be to replace all your plugd and wires, including the coil wire, if that doesn't fix it, replace the coil... Then if that doesn't work, it'll be a new Opti for you.
Old May 24, 2003 | 06:23 PM
Crap, I completely forgot about fuel being a possiable issue! lol... Change your fuel filter, and maybe run some injector cleaner.
Old May 24, 2003 | 06:31 PM
Gripenfelter's Avatar
Do it once. Do it right.
Replace all the wires with Taylor or MSDs and use lots of zipties to make sure they don't touch the headers.
First though, open you hood at night in pitch darkness and look for blue sparks on the plug wires.
Old May 25, 2003 | 04:07 AM
thanks guys...I will check for sparks tmrw.
Old May 25, 2003 | 04:15 AM
ohh, and ive replaced the fuel filter, the wires, and coil wire about 8000 kms ago
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
JasonD
Jul 15, 2002 02:17 PM
FASTFATBOY
Jun 20, 2002 08:58 AM
