What PSI for ET Streets?
Shirl
05-23-2003, 12:16 PM
On the track, what PSI is recommended for ET Streets? (thanks)
rskrause
05-23-2003, 12:28 PM
You've gotta experiment. I found 12.5lbs worked best with my 26x11.5x16. A noticible difference between 12, 12.5 and 13psi, hard to believe as that is.
Rich Krause
rock1501
05-23-2003, 01:16 PM
I usually start about 20 psi and go down 1 psi every run till it hooks good.Our track prep is faily good here so I can usually get away with 18-19 psi but it kinda depends on your power level and if you have tubes.If you dont have tubes I wouldnt go below 14 psi.(to be safe).
Derrick Redd
05-23-2003, 03:37 PM
It all depends on track prep as mentioned. I run 16 psi in my ET Drags.
