Is there any good place to stick an amp?
1COOLPC
05-22-2003, 02:38 AM
Car is a 2002 Z28. I'm running a good size amplifier, an Alpine MRV-F450 17" x 11" x 2.5" Is there some place I may be overlooking? I have a CD changer but it wouldn't fit there any way and I'm not willing to give up my spare because I travel. Suggestions? The only place I can see is against the rear wall of the t-top cargo compartment but I was hoping for 100% stealth. I'm probably out of luck but just in case I'm overlooking something I thought I would ask. Thanks.
slayer6x6
05-22-2003, 02:52 PM
i dont know about the 4th gens, but in my car, which is a 3rd gen, the amp is mounted in the rear storage compartment on the opposite side of the spare.
slayer6x6
PaulN64
05-23-2003, 03:26 AM
you might want to install it in the trunk on the side of the gas tank, flush againts the panel facing the gas tank. I think there's enough room there for the amp and the ttop to fit at the same time.
97FormulaWS-6
05-23-2003, 08:05 AM
I've got 5% on my rear window..... so both of my amps which are LARGE are mounted on custom brackets on the deck. You can see just a slight shimmer of the one chrome amp when the sun is shining directly on the hatch, otherwise it's invisible.
Plus they're all mounted with Tamper-Proof Torx bits.... so whoever wants to remove them is going to have a really really really fun time...
slayer6x6
05-23-2003, 04:29 PM
not a bad idea, ill have to try that:thumb:
