sideways_Into_3rd
05-21-2003, 01:06 PM
all aftermarket seats require to be braced against the cage and i heard u can buy these online and mount them on ur cage and their adjustable etc etc...
does anyone know where to get one ?
CSJTA
05-21-2003, 01:40 PM
I know Jegs sells them, there's two different kinds, depending on what seat you are using, part numbers are 550-40485 and 550-40486. HTH.
sideways_Into_3rd
05-21-2003, 01:54 PM
thanx for that link
but i doubt those would work with my corbeau CR1 seats ..
maybe i'll get something custom built locally unless someone else has some other alternatives !! thanx
Stephen 87 IROC
05-21-2003, 09:28 PM
I welded a bracket to the cross bar that fits up against the back of the seat. I drilled a hole through the front part of the seat for access and bolted the rear part to the bracket with a 1/2" bolt. The seat cover hides the hole and it passes tech. I've seen some fancy seat braces that are adjustable so that you can adjust the seat.
