Sunpro code scanners?
SloMofo
05-21-2003, 10:39 AM
I know Sunpro makes a couple inexpensive code scanners.
Any of them any good for LT1 cars?
I have a 95. OBDI PCM w/the OBDII connector ;)
SloMofo
05-23-2003, 12:45 PM
No one has anything to say about them?:confused:
moparman
05-23-2003, 03:18 PM
I've got the OBDII one. It works good. Have you checked Actron's site to see what the specs are on the code readers? They've got some new stuff out, so there might be a sale on the older stuff.
SloMofo
05-23-2003, 05:16 PM
Originally posted by moparman
I've got the OBDII one. It works good. Have you checked Actron's site to see what the specs are on the code readers? They've got some new stuff out, so there might be a sale on the older stuff. The 9001 model won't work with my car because of the OBDII connector. I assume I need the CP9035, correct?
http://www.actron.com/cgi-bin/web_store.cgi?page=cp9035.htm&cart_id=6179199_10626
moparman
05-23-2003, 07:27 PM
No, the CP9035 is OBDII only. Auto X-ray had an OBDI scan tool that could pull codes from the '95. I think it was around $150. You might check their site and see if it is still available. I think the model # is XP240.
