gearslammer
05-20-2003, 09:16 PM
What were the stock gears in the '95 Z28 8 cyl. carsgearslammer 05-20-2003, 09:16 PM ? Z_Maniac 05-20-2003, 09:45 PM I believe all Auto's came with 2.73s and M6s came with 3.42s... but someone can chime in incase I'm incorrect. shoebox 05-20-2003, 10:07 PM 3.23s were also "stock", but optional with A4s. Red95M6Z28 04-21-2004, 03:38 PM So do ALL M6's have 3:42's? Did any get 3:23's? Is there a way to tell what gears you have based on RPMs@speed? Red96Lt1 04-21-2004, 03:40 PM All M6's had 3.42 Z28Boss 04-21-2004, 11:00 PM I have a 95 Z and I think I have the 3.23's. How can I tell, I once heard something about having a 1st gear selection on the shifter. Oh yeah, I have an A4. Is it true that if I have the 1st gear selection, I have the 3.23's?? Capn Pete 04-21-2004, 11:13 PM As long as your car is stock, then YES, if you can select 1st gear, your car has 3.23's. If you had an LS1 car though, that rule no longer applies (all autos can select 1st gear). Go to www.f-body.org/gears to verify your gears. :cool: | ||
