Some kind of deperate attempt to get the best of both worlds
treyZ28
05-19-2003, 09:21 PM
handlng and strait line
goal is to do both so i started with things that wil help both
weight reduction (aroun 250lbs i think)
SFC
LCA
and im stuck :(
I'm thinking lower the car 2'' and get relocation brackets and some nice tires (ET streets?) for the strip.
think thats enough to cut a 1,6 to 1.7 60 footer?
power is there
stall is 3400 vigi
WheelmanZ28
05-19-2003, 10:19 PM
I think it is definitely possible, what size tires do u plan on running? which brand?
Dan K
05-20-2003, 12:25 AM
Weight transfer isn't going to be very good if you drop the car 2".
I wonder if you could get the 60ft that low.
:think: I'm guessing no.
sideways_Into_3rd
05-20-2003, 12:36 AM
do what i did
get HALs all around .. 35 / 26 sway bars. leave the back height stock .. and drop the front with the hals... i like the stance of my car that way... get the LCA brackets regardless... remove the front bar for drag racing and adjust hals respectively ..
gotta have 2 sets of tires too .. im gonna run 315 Nitto 555Rs and 275 555RIIs for handeling and ET drags / skinnies for the track
done deal !
ps. u can see the stance with front dropped and rear stock height in my sig.
