Mitch2067
05-19-2003, 02:48 PM
Ran into some electrical problems with m camaro, so I can no long use my 12V Ignition wire on the wire harness for installing my aftermarket radio, becuase if i do the radio will be on all the time....
looking for a different wire that would work. I did wiring it into the power accessory wire, but that didn't work either...
help would be appreciated.
slayer6x6
05-19-2003, 05:29 PM
are you sure its not just a blown fuse?? if its not than you can tap off a wire for the heater controls, i do it all the time at work
Mitch2067
05-19-2003, 08:54 PM
I'm sure its not a blown fuse...
one of my modules isn't working so in order to use my radio or power windows, I have to bypass power from the 30 amp defog/seats fuse to the 30 amp windows fuses, so my power windows and radio works...
the only problem with this is I now have constant power to the windows and radio... meaning I can use my radio and windows when the car is off and my radio no longer turns on and off when i turn my car on and off...
so isn't of trying to replace a module, which i have no idea where its located in my car i'm going to just trying and use a different 12v ignition wire...
slayer6x6
05-19-2003, 10:08 PM
sounds like your hacking up all your wiring:p
