Deck resets..
mrronatron
05-18-2003, 10:31 PM
Everytime i turn off my car and turn it back on the deck resets...any answers?
LS1 RULZ
05-19-2003, 06:34 AM
Sounds to me like you don't have it wired correctly. One of the power wires should stay hot even with the key in the OFF position.
firebirdude
05-19-2003, 11:21 AM
Originally posted by LS1 RULZ
Sounds to me like you don't have it wired correctly. One of the power wires should stay hot even with the key in the OFF position. Yep. That is 95% likely the answer. You are using an ign. wire where you should be using a batt. wire.
slayer6x6
05-19-2003, 05:47 PM
if its wired correctly, hook a meter up to the constant wire and see if its reading anything. i had a car that after i shut the car off it would only send the constant wire 4V and thats not enough to keep memory. check the easy stuff first before you go searching for draws in the circuit.
