oldschool 05-17-2003, 06:06 PM hey guys and gals...
this stuff is forsale for the only reason of making money to pay for a 9-inch...so it's all in tip top shape!!!
Phantom Tach w/shiftlight. Never installed in my car, used to be Johnny's and is in PERFECT condition
Stealth Sub-box with Kicker impulse 10"er. Perfect....cost me $500 last summer.
RockfordFosgate Punch 100z2. Nice amp, not a superpowerful amp but will definately wake the neighbour if thats what you want.
MAC Rear-end girdle...Armen has dibbs but if he doesn't want it, it's got to go. Brand new, never installed
2 WS6 rims, one with good rubber
MAYBE my BBK 52mm Throttle body...bought it off Mike Servio
other stuff when I think about it
shoot me some offers...if it's REASONABLE, consider it sold.
Andy
zman0069 05-17-2003, 08:09 PM let me know what you want for the stealth if its a passenger side....
bunker 05-18-2003, 06:26 AM I kinda descided not to go with a 9 inch myself because aparently it robs even more power then a 12 bolt, significally more then the 12 bolt, when the 12 bolt robs quite a bit compared to the stock 10 bolt, so maybe its just worth it to go with a 12 bolt.
mr_muff 05-18-2003, 01:29 PM if armen passes on the grill ill give ya 200 for it
oldschool 05-18-2003, 02:23 PM Armen has passed on this one, so how about we meet in the middle on this one @ $215 and I will drop it off to you as well....
Andy
(604) 764-9221
PS= Phil just pulled a 1.7 60ft in an m6, stock 10-bolt with this cover and the rear-end didn't break!!! :cool:
Rybar 05-18-2003, 03:06 PM Originally posted by bunker
Actually the 12-bolt didn't feel like it robbed any HP at all. :D
You should be fine either way Andy.
oldschool 05-18-2003, 03:21 PM The 12-bolt weighs way more than a 9-inch, but the 9 robs 1% more power. I will give up a little HP inorder to have WAY more durability and that shouldn't matter though because I'll be going to a deeper gear anyways!
Andy
bunker 05-18-2003, 03:36 PM Hmm... I heard its heavier & robs more HP, well then sweet :)
spo/z mike 05-18-2003, 05:20 PM Girls are going to love it :D :D :thumb: :thumb:
sideways_Into_3rd 05-18-2003, 05:42 PM Originally posted by spo/z mike
bawaaahahahah LMAO :D
not if its bent though :D :D :thumb: bahahahahahah
bunker 05-19-2003, 05:06 AM Here is some stuff I found out about 9" vs. 12 bolt:
There are two choices here – the Ford 9" rear and the GM 12-bolt. This is the first choice to make. The Ford 9" has a number of advantages, including:
Low cost
A drop-out pumpkin, allowing quick gear changes
Indestructible.
But it seems to have a few drawbacks too:
No plug-and-play setups available, all seem to be "some assembly required"
The pinion is located further below the axle centerline (2.25" vs. 1.50" for the 12-bolt), offering the potential for pinion angle setup problems. This is also contributes to the next problem.
It has a higher internal friction loss. Published data indicates the GM 12-bolt has an efficiency of 93%, about 3% higher than the Ford 9" which is 90%. In a 500HP setup, this will cost you 15HP. (Ref: National Dragster, 11/10/99, "What’s The Diff?" by Bruce Dillishaw)
No ABS available.
It’s made by Ford.
The Ford rear end is also 38 pounds heavier then stock, I couldn't find out how much heavier the 12 bolt is then stock.
oldschool 05-19-2003, 01:30 PM ABS IS availible now and is considerably more weight than a 12-bolt
CoryM 05-19-2003, 01:42 PM When you guys talk about 12 bolts, what size ring gear are you using? The stock GM 12 bolts came with a 8.88" ring gear but many aftermarket 12bolts use a 10" ring gear. I always assumed that you guys would be using the 10" but when I hear you guys say a 9" is stronger than a 12bolt I have to wonder. Id rather have a 10" ring gear than a 9" anyday. Size does matter, even if your GF tells you otherwise ;) .
CoryM
G-RideZ28 05-19-2003, 02:19 PM hey andy, how much for the tach??
let me know!
pablo
oldschool 05-19-2003, 02:28 PM $330 brand new...
$275
w/reciept
Andy
bunker 05-19-2003, 03:40 PM I belive its the 10" but the Ford 9 inch is still stronger, I also read something about the 9" using 4 bearings to support the axles instead of 2 like the strange, or some crap I fergot, either way, the 9" is way stronger then the 12 bolt I know that from reading for hours, the 9" is called indestructable, now a 14 bolt :)
sideways_Into_3rd 05-19-2003, 03:48 PM 12 bolts only use a 8.8" gear .. their wimpy :p
im thinkin about selling mine actually
NiteRider 05-19-2003, 03:56 PM Andy how much for just the stealth box?
Ken S 05-19-2003, 03:57 PM I know some places are selling 4 channel ABS for the 9", meaning there is a reluctor ring on each axle... This is for people with traction control.
I've heard rumors of people that have gotten a 3 channel setup ABS for the 9"
mr_muff 05-19-2003, 05:52 PM tried sending a pm but your box is full :0
yea ill give ya 215 for it, you gunna be at the next meet? i can give ya money and pick it up then if you don't mind waiting a week. if not ill give ya a call and we can arrange a place to meet or something sooner.
oldschool 05-20-2003, 02:14 AM Sold to the man with the Red SS!!!
Sounds good to me bud...I'll have it with me.
Andy
PS= My box was empty and I haven't been getting any pm's like I used too...something wierd about that:confused:
PSS= I decided not to sell the stealth box because I spent a tone of money on it and don't want to be left with an amp and extra sub (I already have 2 12" sitting in my basement)
