oil pan 4
05-17-2003, 06:38 AM
What does it take to break pistons, rods or crank in a stock bottem end?
How much power can a stock 3.4 bottem end take?oil pan 4 05-17-2003, 06:38 AM What does it take to break pistons, rods or crank in a stock bottem end? MustangEater82 05-17-2003, 01:19 PM i do not know but if you are running stock pistons I cna tell you that is defintely the weak point of the motor. If I was at my place i could link you to a pick of my shattered piston from my 2.8L. FieroGtNOS 05-17-2003, 07:48 PM what do you plan on doing to it? it all depends really on tuning. You can have a bit more then stock but if its not tuned and runs lean you could burn a piston and such. Or if your CC is dirty you could get detonation and could break a piston that way too and on stock power levels If tuned right, I would say the stock internals can probably go to about 250 hp. Pistons are the weak spot. Shaun | ||
