stock 4L60E with 100 shot...is it safe??
TMDZ28
05-16-2003, 07:06 PM
is it safe to have stock tranny while spraying 100 shot of nitrous?? thanks
Dave 96TA
05-16-2003, 08:00 PM
i'd say its safe, sure...but depends how you do it. make sure to get a window switch and set the upper limit to a couple hundred RPM below the RPM shift point so it doesnt spray through the shift. N2O helps produce profound amounts of torque, and shooting that between gears while it dis/engages is likely to cause problems down the road. make sure to use a WOT switch also so it wont activate until you drop the hammer in first (while above the window switch lower limit).
TMDZ28
05-16-2003, 11:53 PM
how do i know what is my shifting point man??
Dave 96TA
05-17-2003, 12:09 AM
you have a tachometer? ;) i think the default rpm shiftpoints for the F-body 4L60E is 5750(?). i believe in the PCM its programmed as a mph (calculated by the rpm and final gear ratio). given these numbers, i'd shut it off after 5000 but before 5500. thats just me - i dont have an A4 and i've never sprayed one.
Derrick Redd
05-17-2003, 12:40 AM
Like mentioned, don't spray through the shifts and it should last. :) With a stock cam there is no need to spin higher than the factory rev limiter. I'd set the window switch at 5,500. :cool:
TMDZ28
05-17-2003, 02:40 PM
what about if i set it at 5000 RPM?? will it be safe??
Loadre
05-17-2003, 03:41 PM
5000 would be safe, my window switch cuts off at either 5500 or 5600 on my A4.
TMDZ28
05-17-2003, 05:56 PM
cool...thanks guys
