Anyone have a '96 Camaro Z or SS in Detroit area? I need a 20 minute favor...
JasonD
09-04-2002, 10:03 AM
If any one has a '96 Camaro (with a V8) and lives in the Detroit area, would you mind helping me out?
I have a wheel that was supposedly made for my '96 but it will not fit on my 2002. I never put it on the '96 so I need to test it to see if the '96 and '02 cars have the same backspacing/wheel wells.
If you don't mind helping me out, I will drive to your place with my jack and wheel, carefully jack up your car, take your wheel off, and just attempt to fit my wheel on the hub and see if it fits. After that, I will out your wheel back on. I don't have to drive the car, put lug nuts on it or anything. Just gotta see if my wheel fits on the hub and in the wheel well. That's all.
If you can help me out, let me know!
Jason Debler - Webmaster/Editor
CamaroZ28.Com * TurboBuick.Com (http://www.turbobuick.com) * ChasingStanley.Com (http://www.chasingstanley.com)
2002 Camaro SS
Zdriven
09-04-2002, 10:28 AM
JasonD,
I don't have a '96, but I did have a '94
and now I've got a '98. I had the same
wheels on both cars. The wheels fit the
same on both of them. I have heard that
the LS1 brake system is larger and will not
allow earlier wheels to fit.
Hope this helps.
1998 Z-28 Conv. stock for now.
M6, Leather, SS Chrome wheels w/ F-1's
14.06 Sec @ 104.76 mph w/2.35 60'
(need launch practic BAD)
BlkDth
09-04-2002, 10:31 AM
You can use mine if you feel like driving to warren. 12 mile & dequindre area.
Stock 96Z28 all opt. ex.t-tops
cASe SenSiTive
09-04-2002, 10:45 AM
Jason, it's not the brakes you need to worry about, but from what I've heard part of the hub is slightly larger on the 97 or 98 and up cars. Sometimes wheels fit fine, and other times there's the need for very slight "massaging".
No difference in back-space or anything like that though.
Tom
1997 30th Aniv. SS <<383 Cubes of Nitrous Huffing Power!
2FASST.com (http://www.2fasst.com) <<< Holy s***! It's really here?!?!
Motown Muscle (http://www.motownmuscle.com) <<< Dedicated to today's musclecar!
2002 Ford F250 Powerstroke diesel. More torque than my racecar!
"...Now go away, or I shall taunt you a second time!"
Chris Ja
09-04-2002, 10:59 AM
Jason so you got a 2000 SS I take it. Did you get another black one? Tell us about the new ride.
87 IROC L98 700R4 A few mods. Best et 12.96 at 110 mph
All motor No NOS or Supercharger.
96 WS6 FORMULA Best et 13.5 at 105 mph
JasonD
09-04-2002, 11:04 AM
I the brakes are not the problem. The hub might be, but I don't think so either.
The reason that I ask is because I ordered a set of wheels for my '96 but never put them on. I tried to put them on my '02 and couldn't even get it on properly because the tire would squeeze against the inner wheel well before even getting it snug against the hub. If I were to even try to tighten the lugs nuts down and drive 10 feet, it would rip the tire to shreds. I want to make sure they sent me the wrong wheel and not the right wheel for my '96 but won't fit on my '02 due to a possible design change in between. Get it? http://web.camaross.com/bb/biggrin.gif
I measured the backspacing of the wheel and it came out to 7.75 inches, which I think to be WAY too big.
2002 Camaro SS
[This message has been edited by JasonD (edited September 04, 2002).]
cASe SenSiTive
09-04-2002, 11:47 AM
Hmmm... There wasn't any changes that would have made that much of a difference. I'd guess that the wheel is completely wrong for the application.
I know that for 15"x10" drag wheel, the correct backspace is 7.5", so 7.75" is plausible for a wide rim.
You're welcome to test-fit it on my car if you like. I'll be gone all weekend though.
JasonD
09-04-2002, 11:55 AM
<font face="Verdana, Arial" size="2">Originally posted by cASe SenSiTive:
I know that for 15"x10" drag wheel, the correct backspace is 7.5", so 7.75" is plausible for a wide rim.</font>
Hmmm...maybe it IS the hub then. Now that I think about it, it was dusk when I tried to put it on. Still, I could swear I had the wheel lined up on the studs just fine. I remember I could push really hard and get the wheel to sit flat against the hub but it would be squeezing the tire against the wheel well. So, I still think there is something wrong with the wheel, but I am gonna go over to Frezza's house and chack it out. BTW, it is a 17" x 10.5" with BFG Drag Radials.
2002 Camaro SS
BlkDth
09-04-2002, 12:23 PM
<font face="Verdana, Arial" size="2">Originally posted by JasonD:
</font>
You didn't reply to my post or email, should I take it you don't need the help http://web.camaross.com/bb/confused.gif
JasonD
09-04-2002, 12:47 PM
<font face="Verdana, Arial" size="2">Originally posted by BlkDth:
</font>
I appreciate the offer, but right after I posted this Frezza let me know he was gonna be home. I gotta head over there anyway.
Thanks again!
2002 Camaro SS
TA Jack
09-04-2002, 02:15 PM
What size tire are you trying to fit on the rear?
I had to file down some WS6 rims to get them to fit on the hub, nothing major, about 3 RCHs off the center hole. They fit on the front fine, it was just the rear.
Mike Meyers
09-04-2002, 03:53 PM
I tried to put a friend's 97 SS rims on my car (94) and they wouldn't fit. The hub definitely changed. Not sure if it was 96 or 97 that it happened.
When I got my Vette rims, they wouldn't fit either. One quick pass around the inside of the rim with a dremel and they fit.
Red 1994 Camaro Z28
UltraZ hood, RKSport gound effects
Stock heads, stock manifolds, stock TB, stock gears, no power adders:
13.34 at 102.11mph on 18s
www.detroitstyle.com (http://www.detroitstyle.com)
Now with Hooker longtubes, 58mm BBK TB, and MSD, but no new times yet. Looking for 12s.... :)
QUASAR BLU
09-04-2002, 08:39 PM
A 2000 16" trans am rim would not fit on my 95 Z28. The hub in the LS1 cars is bigger, and the rim was "loose" on my smaller hub.
hope that helps http://web.camaross.com/bb/smile.gif
JasonD
09-04-2002, 08:54 PM
All figured out, guys. Thanks for the offers to help!
2002 Camaro SS
pipebender
09-04-2002, 09:52 PM
Let me guess...
You jacked it up using the frame and the tire was pushing against the axle rebound rubber because the axle was droped down?
close?
Ken
85 S10,305/350,Carter AFB 650cfm compseries carb,Edelbroc Performer Rpm man.
Dual exaust w/ X-pipe and flowmasters,Sanderson Headers,3:42 Posi,Lakewood bars and lowered
I Love Cheap Speed!!
JasonD
09-04-2002, 10:07 PM
<font face="Verdana, Arial" size="2">Originally posted by pipebender:
Let me guess...
close?
Ken
</font>
Bullseye. How'd you know? Been there?
2002 Camaro SS (http://www.camaroz28.com/~jason)
pipebender
09-04-2002, 10:12 PM
I've worked on a lot of F-bod's in my shop
and the ones with wide wheels (deep backspacing)bind on the bump stops when you lift them by the frame... http://web.camaross.com/bb/biggrin.gif
If I had been on this morning I could have told you to put a floorjack under the axle and try again...
Ken
[This message has been edited by pipebender (edited September 04, 2002).]
JasonD
09-05-2002, 12:10 AM
<font face="Verdana, Arial" size="2">Originally posted by Chris Ja:
Jason so you got a 2000 SS I take it. Did you get another black one? Tell us about the new ride.</font>
Chris,
See the sig! http://web.camaross.com/bb/smile.gif
2002 Camaro SS (http://www.camaroz28.com/~jason) - DMS Springs (http://www.dynamicmotorsports.com) and BMR Suspension (http://www.bmrfabrication) coming soon!
v6maro
09-05-2002, 09:31 AM
I had this exact same problem when I bought some 2k firebird wheels from Rod442. The hub size did change when they went to 2k. Only one of the wheels didnt fit, the right rear, what I had to do was turn the rim over, and on the inside part behind the center cap there is an extra lip on the rim. I took a dremmel and made it even with the rest of the rim and put it on, not a problem since for the 1.5+yrs that I have had them.
hope this helps
-Steve
1994 3.4L V6 A4
2 - 12" JL Audio 12w6's
JL Audio XR650-CSi (front) JL Audio VR650-CS(rear)
JL Audio 500/1, 300/4 amps
custom box, custom rack, dist block.
http://www.fbody.com/members/v6maro/
www.streetlethalperformance.net - 4th gen f-body car club
BlkDth
09-05-2002, 09:59 AM
Ken
</font>
Is the problem solved just by jacking the car up, or is that just how you found out what the problem is?
Maybe you can help me on my question about Z06 rims fitting on my 96 camaro...
JasonD
09-05-2002, 01:54 PM
Is the problem solved just by jacking the car up, or is that just how you found out what the problem is?</font>
When the car was jacked up by the body point in front of the rear wheel, the rear axle would hang lower than normal. When placing the wheel/tire on, the tire would hit the bump stop. So, I put the tire on as far as I could, put the lugs on and hand tightened them. Then I set the car down and used the wrench to tighten the lugs completely. Perfect fit when weight is placed on the car, just not when the car is jacked up.
TealV6
09-05-2002, 11:53 PM
Sounds like you need to start getting your hands dirty again soon. Stop playing with the computer and let's play with the 02 http://web.camaross.com/bb/smile.gif Let me know when it's time to do the suspension. I'm getting eagar now. I've put on many miles this week and want to have my butt closer to the ground via the drop kit!!
Steve
Chris Ja
09-06-2002, 11:47 AM
Sweeeet!
