Knowklew
05-15-2003, 08:39 PM
How long does it take to bolt on the SLP Loudmouth and the SLP y-pipe? And also how long will it take to install the flow pac from SLP?
Bolt-on stuffKnowklew 05-15-2003, 08:39 PM How long does it take to bolt on the SLP Loudmouth and the SLP y-pipe? And also how long will it take to install the flow pac from SLP? stik6shift98 05-16-2003, 01:33 AM no more then 2 hours mattbaer 05-16-2003, 03:02 PM Just had the SLP Loudmouth installed on wed night. It took just over 1hr. BlueNWhiteTA 05-17-2003, 01:32 PM It should not take more than 2 hours. HOWEVER, Note: SLP will include directions on installation. If you do not want to cut the stock exhaust off, and would rather remove it as a whole, DO NOT FOLLOW THEIR DIRECTIONS! You can't drop the rear axle enough to bring the exhaust over it unless you are on a lift. I tried it on jackstands and it ended up taking me around 5 hours because I had to remove the clamps, remove the panhard bar, shocks, and lower the suspension, and then I realized it wouldn't come out, so I had to bolt EVERYTHING back together and cut the exhaust off anyway. So much for keeping the stock parts....I destroyed the piping with a hack saw:D | ||
