foshizl
05-15-2003, 06:15 PM
which gears should i get gonna get LSD but what gears 3.73 or 3.42s also where is the best place to get the 1 piece drive shaft?
3.73 or 3.42foshizl 05-15-2003, 06:15 PM which gears should i get gonna get LSD but what gears 3.73 or 3.42s also where is the best place to get the 1 piece drive shaft? 1fastV6 05-15-2003, 06:42 PM what an original question:eek: 3.73s and a junkyard. but thats just my opinion. if you do a search you will find other peoples opinions also. foshizl 05-15-2003, 07:26 PM Are the drive shafts interchangable i found some on ebay but not sure if it will work Wolfie 05-15-2003, 08:03 PM auto i'd do 3.73 5 speed i'd do 3.42 MustangEater82 05-15-2003, 08:22 PM I like my 3.42s all around for a normal street car, 3.73s may be too aggressive for a 5-speed. I am jsut giving my info on a 5-speed, since that is what I have, no idea for auto. As for driveshaft, all driveshafts 82-02 are interchangeable. For what its worth 80% of drivetrain components are interchangeable from 82-02. Ls1 aluminum ones seem to be the affordable lightweight ones, I have heard them cost $120-170, but usually $150. Lt1 driveshafts are lighter then the stock 2 piece one but not as light as an ls1 driveshaft only costs abotu $25. Check the local sections of F-body boards, alot of guys jsut want the old crap out of their garages, then try local junkyards, then try internet junkyards. I got 2 used tires with 50% tread for free, and a entire stock z28 catback for free, nice even if I jsut used the 2.75 in I-pipe. junkyards have the tendency to rape you. ibanez6rg 05-15-2003, 09:38 PM 3.73. You need all the help you can get to make a sixer faster ;) 96LT14u2Nv 05-18-2003, 04:16 PM 3.42's if u it is just a cruise car, 3.73's for drag racing. | ||
