breaking rear ?s
Black01_Z
05-15-2003, 01:44 PM
With BF Goodrich Comp TA G-force drag radials and 3.73 gears will I be saying good bye to my rear soon or should I be fine?
EDIT: the tires are 285/30/18
AL SS590 M6
05-16-2003, 03:02 AM
With an A4 you can run pretty hard and fast with sticky tires without a problem.
I run 3.42s, 3800stall, and ET streets. Low to mid 12s @ 108-111mph and I go to the track a LOT:D
in2ta
05-17-2003, 04:56 PM
If your rear is set up good enough you can put 4.10s stage 3 heads cam nitrous and slicks without it breaking I have been running like that for a year and no problems at all
96LT14u2Nv
05-18-2003, 02:25 PM
i agree, u should be fine with it being a A4. i might suggest welding your axle tubes as a easy protective measure
