Knowklew
05-14-2003, 11:14 PM
I have a 2000 Z28 Auto and i am just wondering what the stock gears are in the rear? and what is a good gear to upgrade too?
Gears??Knowklew 05-14-2003, 11:14 PM I have a 2000 Z28 Auto and i am just wondering what the stock gears are in the rear? and what is a good gear to upgrade too? curt96ws6 05-14-2003, 11:28 PM Look on the driver side door or inside the glove box for the build sticker with codes. If you see GU2 you have 2:73 if you see GU5 you have 3:23. A good gear ratio to upgrade to is 3:73. Hope this helps. Curt rncotton 05-15-2003, 10:03 AM Ditto ... For the A4, changing the rear to a 3.73 ratio will really wake up your car. And, if you REALLY want to go fast off the line, do a 3.73 rear and a 3000 stall TC. If I still had the Z28, that's what would have been installed. Knowklew 05-15-2003, 01:19 PM Ok i went out and checked the RPO's and i have the 2.73 gears which blows monkey balls. So i wanna do the 3.73 gears..... Who is a good brand to go with and how hard is it to do? Any help is appreciated...I live in McHenry Illinois if there is anyone local around me z top 05-15-2003, 01:25 PM if you look at the shifter console and it has 1 2 d od n p than you have the performance rear axle which is 3.23 if it just says 2 d od n p than you have the 2.73. now if anyone knows for a fact that this isn't so please let me know because this is what i gathered from an article that i read awhile ago. z top 05-15-2003, 01:28 PM if you do get the 3.73 gears you might want to save up and buy some bigger tires you might get a slower time do to excessive tire cooking Black01_Z 05-15-2003, 01:41 PM Originally posted by z top if you look at the shifter console and it has 1 2 d od n p than you have the performance rear axle which is 3.23 if it just says 2 d od n p than you have the 2.73. now if anyone knows for a fact that this isn't so please let me know because this is what i gathered from an article that i read awhile ago. Nope I have 1,2,d, od and have 2.73s Knowklew 05-15-2003, 02:45 PM but what brand do i go with for the gears? I know SLP sells the 3.73 gears and the install kit but i was just wondering if there were any other brands that are maybe better. GoFast908Z 05-15-2003, 02:52 PM Originally posted by Black01_Z Nope I have 1,2,d, od and have 2.73s I have 2, d , od, and have 2.73s :alert: z top 05-16-2003, 04:58 AM Originally posted by Black01_Z Nope I have 1,2,d, od and have 2.73s are 100% sure because i read something in a gmhtp and it from what it sounded like you would only see a 1 in the gear select column if your car came with the performance axle ratio wich would mean it has 3.23's in it. | ||
