Claybar questions
V6 Punk 93
05-14-2003, 04:30 PM
If weather permits, I will be claying/zaino'ing my car this weekend. I was wondering whats best to lubricate the clay when using it on the car. Can I use just plain old water? Or should I use some sort of car wash? I don't have the Z-7 car wash, so what would be a good alternative?
LaSSt One
05-14-2003, 04:48 PM
No Z-7?!?! Get some! or use some other car soap mixed with water in a spray bottle. Plain water won't cut it. Need some soap mixed in to lube it up. And use alot of your lube mixture on the area you are claying... the more the better. Then hang on to the clay, because it can slip right out of your hands.
95 3.8
05-14-2003, 11:53 PM
DANG:eek: lasst one... your cars is the BOMB!!! I was looking forward to buying a 99 v6 vert from orlando, but they never returned my calls.
LaSSt One
05-15-2003, 11:29 AM
Thanks, 95. That sucks no one returned your call. Was it a dealer?
MikeLS
05-15-2003, 01:06 PM
I always use a car wash soap (Zaino Z7) and water as lube. I mix the soap just like I was about to wash the car, and use the soapy solution with a clean mitt to lube the surface. You NEVER want to use straight water for lube, but you can also use a QD spray if that's what you like to use. I've had excellent results from the standard soap+water+suds routine.....
:thumb:
95 3.8
05-15-2003, 03:37 PM
private party... 99 chevy camaro (v6 vert) pewter. gray leather. 60k mi. $10000. I checked the link but it seems it has been sold.
