Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
12 bolt is installed!!!
Old Aug 22, 2002 | 06:43 PM
Black Sunshine/ 00SS's Avatar
Post 12 bolt is installed!!!
Started yesterday, ended today. I dont have power tools, & I like to take my time, double check, tripple check.
Took it down the road a few miles at a slow pace, waiting to hear unusual sounds. The only sound I got is this unbearable howing from the gears. I hope that eases up, I'll go nuts.
Had ABS INOP light on, along with brake light (even though brake was completely off). Went 2 miles in reverse also, at a slow pace, then home. Stopped in the drive & left the car running while I swept out the garage, the car suddenly stopped running, instantly, on it's own, and the lights came on (it is getting dark because of rain coming in). The dam car is possesed. I got in started it up, and ABS & brake light went away.. Go figure.
So, got a few more hear cycles to get in, and I want to get the car on a lift & check every bolt with an air gun, just to make sure, then I can hammer it down & check this out.
Missed the dam UPS guy while running for parts.. I think it was the cam.. Maybe I'll do an early heat cycle & after a few hrs of cooldown, start breaking it down for the cam install...
hchap63@hotmail.com
01/SS, Black A4, TR224/112, ARE stage 2 heads, lid, FTRA, PMAF, PTB, Grott LT, true duals, NGK, ASP pulley, Vig 3200, LCA, poly TAB, Convo pros, ET Streets, 3300 raceweight. Little bit of juice..
Best ET: (All bolt ons) 11.496@116.42 (1.52)
Current best after Head & cam & nitrous:
10.88@124 (1.60)
Motown Muscle King of The Hill winner 6-8-02. Want some? Get some!!
RIP #3 Dirty Dale!!!
Old Aug 22, 2002 | 07:54 PM
AL SS590 M6's Avatar
Moderator
Question
Harold,
Are you serious about the howling gears?
If so don't drive it. Get a hold of the vendor and get it fixed.
When we put the 12 bolt in Rod 442's car it was and as far as I know still is as quiet as a stock rear.
Moser 12 with 33 spline, eaton posi, and ta cover.
Al
Blue Green Chameleon 2000 Formula Hardtop
A4, 3.42/Eaton HD posi TA cover, Raytec sleeve, ARP studs
Yank ST3500, TransGo, & cooler
FRA, Direct Flo/K&N, EGR bobbitt, HPP
!TB coolant, Just Me Thermo mod, ATI dampner
SLP resonator exhaust, ES tranny&torque arm mounts
Home Boxed LCAs/ES bushings, LCA relocators
Best 60' 1.749
Best 1/8 8.100 @ 86.45
Best 1/4 12.704 @ 106.68
Best Mph 109.72 with a tail wind
and her
Black '98 SS# 590 M6
T-tops, Leather, Loaded
lt1car's Avatar
Post
Congrats. Post *****
99 Pewter Transam. T-tops. Leather. M6 Only 3 mods. $150 total. True dual cat back. Whisper lid. Ported Maf. Borrowed ET Steets.
12.8 at 108mph. 1.8 60ft 90 degree Humid day.
Old Aug 22, 2002 | 10:05 PM
derty's Avatar
Post
Got home at 6pm today. So far I've got the Piece O SHEIT 10 bolt out and everything disconnected. I just finished putting the 12 bolt up and in. Got the springs and LCA's back on it. Tomorrow I have to get my exciter rings and bearings pressed on. Should have it back together by 5PM or so. Do some heat cycles and we're off! If I hear howling I'm going to be PISSED!
Grand Rapids, MI
2002 WS6
http://www.sigma-epsilon.org/steve
stevedertien@attbi.com
Whisper Lid, Grotyohann Headers and Y-pipe, Corsa Exhaust, BMR SFC's, McLeod Single Disk, Spohn Torque Arm, LCA and Panhard Rod and much more to come
Old Aug 22, 2002 | 11:34 PM
91 Redd Sledd's Avatar
Talking
Congrats Harold,
Now just get everything tightened up and get me some pictures of you spraying out of the hole with the wheels up.I have showed that video to a few guys at school and they are all impressed with your ride.
James
Old Aug 22, 2002 | 11:37 PM
Post
Oh by the way,we are in axle lab out here at school.Call me or post up what noises and when the noises are occuring and I might be able to help ya troubleshoot it.I know it's probably got a gaurantee and all but we can still troubleshoot it.
Old Aug 23, 2002 | 06:49 AM
Grover's Avatar
Post
My Moser gears also howl, and it says right on Moser's sight that their gears are going to howl because of the high nickel content in them which makes them stronger.
Just turn the radio up!!
Chad Beebe
'97 T/A WS6 M6 Dark Metallic Green
CC 306 cam and some other stuff.
My Car
12.762@109.13 with 1.828 60'
Best 60' 1.816
Old Aug 23, 2002 | 08:14 AM
Post
If it's going to be something that I have to live with, then I might as well go back to the bullets & have everything loud.
I'll take it through a few heat cycles & see how it works out. It was my cam that was here already. Why the hell would I have to pay $21 COD on the cam? If not for that, they would have left it. Dam, now I gotta stay home all day. At least it's coming together.
James, the noise is when you give it gas, and goes away when you let off. Is this typical to what you have Chad? Or Rod? I was hoping for something quiet, but I understand that they put more nickel in the gears now to make them stronger. I'll warm them up again & see what shakes out before calling the vendor. No wheelie shots James, for about a month, I gotta figure everything out first, & get piece of mind. Hope yours works out Steve. Mine did take more than the 3 Qt's provided, I didn't every think it would stop taking in fluid.
Old Aug 23, 2002 | 08:26 AM
derty's Avatar
Post
Sounds like there is too much backlash in there. When I replaced the posi in the 10 bolt I created the same issue. I never adjusted for the backlash. I'm guessing I had about .005 to .007 backlash in there. The new rearend here has maybe .002 backlash at most. It's TIGHT! Watch me still bitch about it when I fire it up.
I've got 3 1/2 quarts of oil, we'll see how well it comes together.
Why did the cam come COD? Mine came in a box and they left it at the door.
Old Aug 23, 2002 | 09:17 AM
Grover's Avatar
Post
My Moser whines all the time, it doesn't change at all on accel, coast, or decel. The 10-bolt I had that Modern Musclecar set the 4.10's up on were quiet on accel and coast but would howl on decel.
I just did the normal break in that Moser recommends: run in forward and reverse for 3 minutes(did on jack stands), take for a drive to get to temperature and let cool. Then I went racing the next day at M6.
Old Aug 23, 2002 | 12:11 PM
Redbird's Avatar
Lightbulb
Harold... last night I did my 12" installation, went slow, double/triple thrusted, etc... just like you!
Derty... I got new exciter rings last month,
wife loves them!! You musta got the wrong size if you have to press them on! My XX-LG.'s slip right on with a little KY jelly.
Chad... I've got $2.00 worth of nickles to put into my rear axle, would that be enough to get a good/high nickle content? Do I have to melt them or just put them in out of my pocket??
HInk
[This message has been edited by Redbird (edited August 23, 2002).]
Old Aug 23, 2002 | 12:50 PM
Post
Hink, no more crack for you!! BTW, if the shaft was too big, then obviously the exciter wouldn't just slide right in. If yours did, then maybe you have issues
$2.00 ought to be just enough, throw them in there & let us know how that works out...
Ya, lots of room to stretch out here, forward or reverse, ha ha. Try that in the city.. I feel sorry for you guys It's not the tractors you have to worry about, it's the dam deer.
In defense of the rear, the installer says that they were set up at .009, bu they are Richmond, and I haven't heard any good things about the noise on those. He is sending me, free of charge GM motive gears & paying to have someone install them. Andy, get ready to work!
Appears that was a "Brokerage COD" charge on the cam. WTF..
Well, gotta go & get ready to install the cam. See ya.
Old Aug 24, 2002 | 12:24 PM
derty's Avatar
Post
Well, just got done doing some hot laps around the neighborhood with my 12 bolt. Everything is great, it only howls like an 18 year old when coasting. Under power and decel it doesn't make a noise at all. We'll see what it's like on the highway now. I'll be over by about 3:30 Harold.
Old Aug 24, 2002 | 03:41 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Post
lmao @ HInk& 00SS, you guys are killing me, i have to get back to working on the wifes car (at least that's what i told her)
MY car featured:
www.bmrfabrication.com.htm
1996 Camaro SS A.R.E 398
11.36@120.35mph, NA
10.14@135.11mph N2O(no more excuses )
Best 60' 1.375
Best mph: 135.11mph
oh yeah also an 80 Camaro, an 98 Ram Sport, the latest addition a 94Z28, w/T-Tops!
"...i wish i was the full moon shining off a Camaro's hood..."
P.J.
RUENUF
Mar 13, 2016 03:39 PM
Richardan15
May 30, 2015 08:36 AM
maybe2fast
Mar 16, 2015 09:45 AM
CARiD
Jan 27, 2015 06:27 AM
