Fastrthnu
05-13-2003, 12:04 AM
Ok, I need like around 16 feet of Nitrous High Pressure hose. I don't know the correct term for the hose, but mine has a leak and I suppose I have to replace the entire line? It's the line that runs back to the nitrous bottle, basically covering the length of the car...anyone know where to get this stuff or have any ideas as to what to do? Thanks jason
RacinLT1
05-13-2003, 07:14 AM
you can call summit/jegs/any CZ28.com vendor that sell's nitrous,and tell them you need the 16" bottle to solenoid line.They all can get it.
JJJ93z
02-19-2004, 11:25 PM
are all braided hoses created equal? i mean when i buy my supply line could i buy this.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33740&item=2461840496
even though its not NOS or NX? also how long of a supply line do i need? is 14' adaquete (sp) for a bottle mounted in the rear storage area? or do i need 16 or 18 ft? thanks
RacinLT1
02-20-2004, 11:21 AM
you can buy that. 14' is what i used,worked fine.
But with that line there it is -6 and every entry level kit uses -4 line,and they also come with the feed line. So unless you are piecing together a system,you reaqlly dont need that.
iniviate
02-20-2004, 09:13 PM
you can get it repaired at a hydraulic hose shop.
JJJ93z
02-20-2004, 11:14 PM
thanks for the quick response, youre definately right on the -4an fitting, i was just using that one as an example. are all the -an fitting hoses the same ? or are there "nitrous only" specific hoses?
HeavyChevySS
02-20-2004, 11:22 PM
if you are going to get the fitting fixed, all an fittings for the high pressure hoses like that are fine. I personally would just by a new complete line.
JJJ93z
02-20-2004, 11:44 PM
no im not getting n e fixed, im going to buy the complete line i was just curious if there was a specific type of braided AN fitting hose used for nitrous, like if i had to buy it from NOS or NX or if i could buy 4 an braided hose from Earl's or something
