jtj2000
05-11-2003, 11:29 PM
I went to autozone, he gave me three codes. Then he looked them up. They were
1. Mifire in # 5 cylander
2. EGR Valve
3. Mass Air Flow Sensor
Does this mean I have to replace the ERG Vlave and Mass Air Flow Sensor? Could I clean them out or something? They are both around $100! I don't see how the Mass Air Flow Sensor could need replacing since all it is is something air goes through. I have the SLP Cold air induction, could that be the cause of the problem?
I don't know what the misfire could be. I have all new coils, wires, and spark plugs. I took off the # 5 wire from the coil and noticed it wasn't sparking as rapid as it was when i got it a few weeks ago. I think this could be the reason it came up on the test. So do you think the Ignition Controll Module could need replacing? And where can i get one if I don't want to spend $150 on one? What would you do in this situation? Thanks for listening to me -
Jason
If all else fails how does a 1996 or 1997 mitsubishi eclipse gs-t compare to my car? Would it be an even trade?
2. EGR Valve
Jason
