going up to a 175-200 shot
funina91ss
05-10-2003, 08:48 PM
I have no way of backing off timing but I will be running 104 unleaded I also run autolite 103's gaped @40 if you guys have any more info on things I should do before spraying a 200 shot let me know I dont think the 175 will be a problem.and this will just be for one night our local track is having a heads up street car race. and I think I will need the 200 shot to be competive.(Pray for me:) )
baddest305
05-10-2003, 09:39 PM
i going to try the same thing with the 200 shot but first im buying a bigger fuel pump just to be on the safe side. won't a msd multi-step retart box be helpful? good luck i'll watch for your results:cool:
RacinLT1
05-11-2003, 12:37 AM
i wouldnt do it without a timing retard. There are no other tips,other then make sure the fuel system is working damn near perfectly.
1QUIKTA
05-11-2003, 01:20 AM
Good luck Sean and I heard about Adam's run:bow:
Hawk
05-11-2003, 01:54 AM
200 shot eh?? sounds like fun, let us know how it goes........
Derrick Redd
05-11-2003, 05:28 AM
I ran exactly what you stated above. 104 Sunoco, Autolite 103's @ .040 and a 175 shot NX with no timing removed. I've sprayed 3 bottles without an issue on the 75k stock shortblock. :D
funina91ss
05-11-2003, 09:16 AM
Originally posted by 1QUIKTA
Good luck Sean and I heard about Adam's run:bow: yeah I need to pass his 7.09 I hope with tration,less weight and the xtra juice I can. my best is a 7.50 with a 1.68 60ft.I think this will be my last time out with the stock heads and cam.I was wanting to hit 6's on the stock motor but if I get close I will go ahead and put them on.
94DROPTOPZ28
05-11-2003, 02:19 PM
I would say if you are running the "stock" bottom end the main things you are gonna need is:
1) Adaquate fuel pump
2) MSD digital 6 or retard box to take out 2 degress of timing
3) 100 or better octane fuel
4) And some good tires to put that power to the ground...
:D
funina91ss
05-11-2003, 02:21 PM
:D
Only thing I dont have is timing retard. but oh well..
