NOS MPFI NOSZLE kit??
TCAL95Z
05-10-2003, 02:17 AM
Is anyone using the NOS NOSZLE kit?
If you are where is the best place to buy it? both summit & jegs can't give me much info except a price.
This kit looks great. Why is no one talking about it?
RacinLT1
05-10-2003, 07:27 AM
not many people are using it,not sure if it is due to the price,or the difficulty in using it with the LT1 intake.
The biggest issue with 94-97 LT1's would be the crossover tubes that would have to be shortened or reoved and replaced with braided hose.
TCAL95Z
05-10-2003, 09:16 AM
are you talking about the cross over tubes on the fuel rail?
Why do they have to be shortened or removed?
I priced this kit at around $1500 with a polished bottle which is about the same price as a maf kit with a carbon fiber bottle and the genx2 upgrade. The only problem I see is price because it doesn't come with a bottle heater, blow down tube or purge but I don't think you would need a purge.
Tom
RacinLT1
05-11-2003, 12:40 AM
look at the angle of the fuel rails. they are not stright up and down,that tilt in towards the middle. raise them a 1/2" and they will want to come closer towards the middle,and the balance/xover tubes wont let that happen.
TCAL95Z
05-11-2003, 03:10 AM
ok, I see what you mean. So what would you do cut the cross over tubes and put in a flexible fuel line? Or have a different fuel rail made?
snow2000SS
05-12-2003, 01:07 PM
You could do it if you use after market fuel rails. I've seen it done with the holley fuel rails. It's still not easy but it is possible.
