Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Anyone running ConvoPro rims, want to do some testing?
Old Aug 5, 2002 | 11:04 AM
Black Sunshine/ 00SS's Avatar
Post Anyone running ConvoPro rims, want to do some testing?
I have the 15x7.5 with a 5" bs. I have 26x10.5 ET Street, and same size ET Drag. After I get the 12 bolt in, I would like to experiment with different size tires. If you have the Convo rim & would like to meet at the track & do some experimenting, let me know. This would be after Woodward.
I suspect that I will be needing a larger tire once I am able to spray out of the hole, but would like to confirm that prior to buying new tires. Looking for 27 or 28" tire. Thanks.
hchap63@hotmail.com
01/SS, Black A4, TR224/112, ARE stage 2 heads, lid, FTRA, PMAF, PTB, Grott LT, true duals, NGK, ASP pulley, Vig 3200, LCA, poly TAB, Convo pros, ET Streets, 3300 raceweight. Little bit of juice..
Best ET: (All bolt ons) 11.496@116.42 (1.52)
Current best after Head & cam & nitrous:
10.88@124 (1.60)
Motown Muscle King of The Hill winner 6-8-02. Want some? Get some!!
RIP #3 Dirty Dale!!!
Old Aug 5, 2002 | 06:46 PM
Grover's Avatar
Post
Harold,
Did you get the 12 bolt with the 3" long studs? If so I could let you try my 28"x10.5" ET Drags on Weld Prostars (15x8).
Chad Beebe
'97 T/A WS6 M6 Dark Metallic Green
CC 306 cam and some other stuff.
My Car
12.762@109.13 with 1.828 60'
Best 60' 1.816
Old Aug 6, 2002 | 12:58 AM
Post
I dont have the rear yet, still waiting, but I requested long studs, we'll see when they get here. Would I need spacers for those? I do not have my calipers ground, as they are not needed with the Convo Pros. Are they needed with the Welds you have?
Old Aug 6, 2002 | 11:46 AM
Grover's Avatar
Post
You could either run spacers or grind the calipers. I plan on grinding my calipers as to eliminate a potential shear point.
Old Aug 7, 2002 | 01:32 AM
3FifteenPlus's Avatar
Post
i am running the convo pros and have a 28x9 hoosier on the car wouldnt be a problem swappin
Old Aug 7, 2002 | 11:48 AM
Post
Thanks Chad, but that wont work for me. I got the Convo so that I wouldn't have to grind the calipers. But if you ever take those off the rim to switch to another tire, then let me know.
3-15+, what size rim & back spacing do you have? Also the tire? Thanks.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
naaz90
Jul 27, 2002 08:22 AM
