SubsAnDubs
05-06-2003, 11:05 PM
Does anyone have any tips on how to apply the 3m swirl mark remover. I was unsure if you should apply it with a buffer or by hand. Which gives best results?
3m #39009SubsAnDubs 05-06-2003, 11:05 PM Does anyone have any tips on how to apply the 3m swirl mark remover. I was unsure if you should apply it with a buffer or by hand. Which gives best results? MikeLS 05-07-2003, 09:21 AM http://www.goodspeedmotoring.com/?page=orbital_handpolishing#HAND%20POLISHING A buffer will give better results when used proeprly, however there is a greater potential to do harm with a buffer, if used improperly, than by hand. 3M products seem to be made for buffers IMO. They can be a bear by hand.... :) KevinSS 05-07-2003, 10:43 AM Use a foam bonnet or pad and an orbital buffer for best results. DO NOT let the product dry on the paint, remove while wet. Work the product into the paint with the machine until it breaks down from a paste to an thin oil like coating and remove at that time, repeat if needed. After that, apply your final finish wax or polish. OctaneZ28 05-07-2003, 12:02 PM So, am I correct in assuming that the 3M SMR should be used before Zaino? ...i.e. it will remove Zaino? KevinSS 05-07-2003, 12:06 PM Originally posted by OctaneZ28 So, am I correct in assuming that the 3M SMR should be used before Zaino? ...i.e. it will remove Zaino? Yes, you must use abrasive compounds before you apply any type of final finish wax or polish. | ||
