clasbya
05-05-2003, 07:59 PM
I already replaced the rotor, the cap was still in good shape. Do I need to replace the distributor itself? I am still using my old wires, though I dont think this would cause an error that relates to the distributor.
Error Code: 43clasbya 05-05-2003, 07:59 PM I already replaced the rotor, the cap was still in good shape. Do I need to replace the distributor itself? I am still using my old wires, though I dont think this would cause an error that relates to the distributor. krazzycowgirl 05-05-2003, 08:45 PM Code 43 is Knock Sensor (KS) or Electronic Spark Control (ESC) circuit fault clasbya 05-06-2003, 07:42 AM I was reading in my Haynes and Chitlins(Chiltons) books and they describe the ESC as being part of the distributor. My dad told me he had a big issue with the ignition module on his fiero so I think I will start there. Autozone has a way of testing this module to see if its a problem child or not. I didnt think of the error code meaning a problem with the knock sensor, I will have to take a look into that one. irocz8957 05-06-2003, 08:16 AM yeah i had the same problem i had to replace my knock sensor! clasbya 05-06-2003, 10:52 AM sweet, thanks yo. aklim 05-06-2003, 12:18 PM KS error code could be Bad KS, Bad connection to ECM, Bad wire to ECM or Bad ECM Error 05-07-2003, 07:48 AM Hey, we had this one: We ended up replacing the whole ignition system since it was tripping a few other codes. New cap/rotor/HEI module/& coil and we're back in business. The 305 is still slow though :( clasbya 05-07-2003, 10:05 AM I sure I dont have to go that far. Though I would like to replace my POS 3.1l v6 for a nice v8. Prolly go for a used 350 and have it rebuilt. | ||
