Damen
05-05-2003, 10:05 AM
For the life of me, I cant seem to find Sub Frame Connectors that will fit my '89 IROC Convertible. Every time I think I've found a set, I see a little note *will not fit convertibles
Do you guys know of any/where I can get them?
67 Camaro
05-05-2003, 10:28 AM
http://www.thirdgen.org/techbb2/showthread.php?threadid=73420&highlight=subframe+connectors+convertible
http://www.thirdgen.org/techbb2/showthread.php?threadid=58879&highlight=subframe+connectors+convertible
... might help a little bit :)
-Bud
Damen
05-05-2003, 10:29 AM
Dude, you rock, thanks much!
AutoRoc
05-05-2003, 05:01 PM
South Side Machine subframe connectors honestly hugged BOTH of my thirdgen camaros perfectly. They run the length of the dor and tie into the LCA bolt also at the rear. They lost me NO ground clearance since they're about 1.5" in height, rectangular tubing, they cost around $150 from Jegs I believe and come bar. Weld em and paint em.
On my T-Top car they definately stopped a lot of the hatch creaking and movement and it got rid of some of the overhead glass racket. On the convertible they were weldd in and to the rollbar so overall it's a stuff setup.
If you check out the pics of my car, you wouldn't know they are on there but they sure are. Goodluck!
87DJP2001
05-05-2003, 05:07 PM
Try Spohn Performance for the SFC' s to fit a Conv. $185.00 uncoated tube style. E-mail tech@spohn.net for more info.
Playdough
05-05-2003, 05:21 PM
I have Kenny Brown SFC on 91 and had no probelms with them fitting at all. Hugged the rocker panels and lost no ground clearence at all.
