Is "Goof Off" safe for our finishes?
sleeperZragtop
05-04-2003, 11:17 PM
...I removed the side moldings from my Camaro...and it left this sticky crap behind it....is Goof Off safe for the clear coat?
fbird95
05-05-2003, 12:19 AM
I wouldnt use it, I would use a heat gun carefully instead.
Black_Z28
05-05-2003, 12:46 AM
Yes, it's ok for your finish. Just don't rub too hard on the finish. You might want to let the car sit in the sun for a bit. Then put some of the goo gone on a NICE towel and rub it off.
PurplePonyEatr
05-05-2003, 01:18 PM
It was safe on my car... I used it on the fenders to remove the left over residue from the Z28. Don't use any on any plastic part of your car through... bad news.
sleeperZragtop
05-05-2003, 03:54 PM
Thanks guys...worked very well...I just had to re-Zanio the car..
:cool:
KevinSS
05-05-2003, 03:57 PM
Goof Off and Goo Gone are TWO different products, Goof Off is about 10 times stronger than Goo Gone.
Both are safe for cured paint , just do not leave either on the surface very long.
