99huggerorangeZ
05-04-2003, 03:07 AM
i drained my radiator but i also want to drain my engine block but can not find the plug
coolant99huggerorangeZ 05-04-2003, 03:07 AM i drained my radiator but i also want to drain my engine block but can not find the plug Dave89IROC 05-04-2003, 07:58 AM pass, just is above the oil pan, between the mount and starter, drivers side is the other side of the block, same location 99huggerorangeZ 05-05-2003, 12:13 AM i think i found the one on the drivers side but i cant see the one on the pass side do i need to remove the start to see it. could someone take a pic of the spots just to make sure i am looking in the right place?? TheGreatJ 05-05-2003, 09:15 PM The knock sensor goes in the drain hole on the pass. side, and the driver's side drain is in the same location on the other side. It's between the middle cylinders, about 3/4" above the oilpan rail. aklim 05-06-2003, 02:47 AM Why all this trouble? Why not flush it with water and add radiator flush? Run it for a couple hundred miles and flush again and add coolant? Why do you have to go thru the trouble to drain it? irocz8957 05-06-2003, 08:40 AM it's a pain in the ass to get to good luck with it! | ||
