OrangeIROC
05-04-2003, 01:12 AM
Hey, i have a 1988 IROC-Z, when i'm driving at a constant speed or i get on the accelorator at all, say about 30+mph, there is a whining sound comming from the rear end, and also, anything under 30mph, i hear a clicking noise.. What is it? Spider Gears? I still have Posi and firm shifts, just that dang noise.. What is it and how much to fix it roughly? Thanks guyz..
Mike
Dave89IROC
05-04-2003, 07:56 AM
does it go away when you coast (let off the gas to slow down) ?
OrangeIROC
05-04-2003, 12:39 PM
when i'm driving at like 30+ mph, and i let off the gas the noise does stop, however if i'm under 30mph it will still click.. for for some reason when its over 30 i dont hear clicking, maybe everythings just spinning too fast.. Any ideas?
DarthIROC
05-04-2003, 01:59 PM
Kinda sounds ike mine when the ring and pinion ate it. Mine was torn up pretty bad when I took off the differential cover. But it never made a skip in persormance yet, just bad noises. So I guess it will work right up till when I finnaly decides to tottaly quit working if you leave it be.
TheNovaMan
05-04-2003, 06:33 PM
It might not be a bad idea to pull the differential cover and check the oil for metal flakes. If you find much, you know you've got a problem. If you're lucky (or maybe unlucky?), you might even be able to see the problem.
Zepher
05-04-2003, 07:02 PM
Sounds like you have some cracks in your pinion gear.
Definately pull the cover and inspect the ring and pinion.
OrangeIROC
05-05-2003, 12:14 AM
Hmm bummer, this whole time i was thinking that it was just the spider gears.. So i guess if its the Ring and Pinion gear i should probly just upgrade my gears while i'm at it right? 3:73's sound good to you guyz?
Mike
Zepher
05-05-2003, 12:47 AM
Ya, if it turns out to be the gears, 3.73 sounds good.
