MadMaxz28
05-03-2003, 02:12 PM
im very interested in doing the round headlamp conversion. any kits availible? or what parts would be needed.. also is it possible to stay under $300?
round headlight conversionMadMaxz28 05-03-2003, 02:12 PM im very interested in doing the round headlamp conversion. any kits availible? or what parts would be needed.. also is it possible to stay under $300? 94BlackBowtie 05-03-2003, 04:13 PM Edited - The post was just recently brought current - check it out here. (http://web.camaross.com/forums/showthread.php?s=&threadid=62272) Sam95Z........ (thread starter) is the guy who is making the guide and has a sort of picture guide. I think it runs right at $300 to do as well. That thread should answer just about all of your questions. But you must beware - before doing this mod you have to shorten your sig length by about 10 lines or it won't work. :) stik6shift98 05-03-2003, 05:03 PM u mean the ls1 headlights????? Sam95ZNoTop 05-03-2003, 11:12 PM Originally posted by 94BlackBowtie Edited - The post was just recently brought current - check it out here. (http://web.camaross.com/forums/showthread.php?s=&threadid=62272) Sam95Z........ (thread starter) is the guy who is making the guide and has a sort of picture guide. I think it runs right at $300 to do as well. That thread should answer just about all of your questions. But you must beware - before doing this mod you have to shorten your sig length by about 10 lines or it won't work. :) I have posted a prelim version of the write-up. Only thing missing is the part for the high beams. Hella 90mm Conversion (http://bellsouthpwp.net/m/u/mulgeary/Hella90/index.htm) Sam Brent94Z 05-04-2003, 08:17 AM Every so often you'll see a "kit" pop up on eBay. Here is a write-up on one method... http://www.bfranker.badz28.com/94Z/piaa.htm And, yeah, your sig is way too big... so, from the moderator, please make an effort to shorten it a bit. While it isn't enforced unless extremely violated, we ask people to keep the sig to around 5 lines. 6 or 7 lines will typically be not noticed but when you get up to 10 or 20 then it is hard to look the other way :D | ||
