RENE95Z
05-02-2003, 10:08 PM
Once you lubricate the surface you are about to clay, do you rub hard with the clay, or do you use a buffing type pressure?
When claying....?RENE95Z 05-02-2003, 10:08 PM Once you lubricate the surface you are about to clay, do you rub hard with the clay, or do you use a buffing type pressure? Kevin V 2002 SS 05-03-2003, 12:00 PM You do NOT need alot of pressure. Just lightly rub it across the surface. It pulls out the surface contamination. Flatten it into a pancake shape. Keep the surface WELL lubricated. RENE95Z 05-04-2003, 12:07 AM Thanks, that is what I wanted to know. Rene' | ||
