glennxx1
05-01-2003, 03:58 PM
corvette blocks are aluminum right? camaro block isnt?
camaro block isnt or is aluminum?glennxx1 05-01-2003, 03:58 PM corvette blocks are aluminum right? camaro block isnt? stik6shift98 05-01-2003, 04:07 PM camaro bloxk is aluminum as well bsmith 05-01-2003, 04:09 PM LS1's are aluminum. Capn Pete 05-01-2003, 05:36 PM Aluminium baby, yeah!:D Block and Heads;). Cbra Kilr 05-01-2003, 05:37 PM ls1=aluminum, lt1= cast iron right guys? My84Z 05-01-2003, 05:39 PM correct ls1 all aluminum lt1 cast block aluminum heads..... CPFarhood 05-02-2003, 09:01 AM Truck LS1's are cast :D Capn Pete 05-02-2003, 10:21 AM Originally posted by CPFarhood Truck LS1's are cast :D Ahhh, but they're not really LS1's;). The LS1 is "specifically" the 5.7L:p. The 4.8 / 5.3 / 6.0 are similar designs, but the LS1 & LS6 are the only aluminum 5.7L engines. CPFarhood 05-02-2003, 12:59 PM Either the 5.3 the 6.0 or both are the same block as the 5.7 i forget which (or if it's both) just different stroke. Dr.Mudge 05-02-2003, 01:43 PM 6.0 is an iron block and what most of the big strokers are based on, I dont know about the 5.3 other than heads. PhantomTA 05-02-2003, 04:46 PM the 4.8 the 5.3 and the 6.0 VORTEC Motors are iron block the 5.6 ls1 and ls6 motors are aluminum. The lt1 and lt4's are iron block CPFarhood 05-02-2003, 06:33 PM Originally posted by PhantomTA the 4.8 the 5.3 and the 6.0 VORTEC Motors are iron block the 5.6 ls1 and ls6 motors are aluminum. The lt1 and lt4's are iron block yea dave but isn't the 6.0 iron block the same as a 5.7 aluminum block just a different stroke? PhantomTA 05-02-2003, 11:09 PM no i dont believe so.. Pandamonkey 05-03-2003, 02:25 PM Originally posted by PhantomTA the 4.8 the 5.3 and the 6.0 VORTEC Motors are iron block the 5.6 ls1 and ls6 motors are aluminum. The lt1 and lt4's are iron block Small Edit: The 5.3L that comes optional in the 7passenger Trailblazer/Envoy/Bravada is aluminum.:) The truck 5.3L's are still iron........ PhantomTA 05-03-2003, 04:12 PM Originally posted by Pandamonkey Small Edit: The 5.3L that comes optional in the 7passenger Trailblazer/Envoy/Bravada is aluminum.:) The truck 5.3L's are still iron........ didnt know that Trevor98ramair 05-04-2003, 02:02 AM Originally posted by CPFarhood yea dave but isn't the 6.0 iron block the same as a 5.7 aluminum block just a different stroke? No, the 6.0L is a 4.0" bore with the same 3.622" stroke as the LS1/6. We use the 6.0L block to build our 396 and 408 combos. :) Trevor SS1LE02 05-05-2003, 12:22 AM 98-02 V8 Camaro's are aluminum. There not silver for nothin. I hope you didn't think that was silver paint:eek: j_dog25 05-05-2003, 10:41 AM Ok, the LS1, LS6 and LM7 (the 5.3 Truck Engine) are all the same block design. The LS1/LS6 are all aluminum while the LM7 is Iron block aluminum heads. The 6.0 truck engine is a completely different animal. | ||
