Any companies make ZL-1 hoods?
Are there any companies out there that make/sell the ZL-1 hood? That hood definitely caught my attention when I first saw it. I've seen two versions of the ZL-1 hood. 1) The 2002 ZL-1 Camaro with the stock SS hood. 2) the other black ZL-1 camaro with 13" wide wheels in the rear Anyone got any clue?
You can also buy the original SS hood which includes Air Box Filter, Injection Molded Grille and 2 Hood Struts from GM Restoration Parts for $999.00.
http://www.gm-restorationparts.com/e...ew&SC=D&C=D_HO
Thanks for the replies guys. 1,200 is definitely wayy too much for that ZL-1 replica. It doesn't really even look like the ZL-1 hood anyways. Isn't the scoop portion of it supposed to be about 1" - 2" higher ? If I can get a group buy for a ZL-1 replica hood made out of fiberglass, would any of you be interested? Reason I'm asking, is because there's a fiberglass shop in Orange County, CA that specifically does hoods for muscle cars and they've done group buys for me in the past. (when I had my '99 sebring...not exactly a muscle car)
VFN just finished making thier 3in SS hood. It isnt functional as an induction hood, but is a functional cowl hood.
http://www.vfnfiberglass.com/site.htm
Check at the bottom, the pin on is $480, while the hinge bolt on is $575.
Mark
EDIT: go to catalog and pick your car....the good is for 98+ cars only.
Mark
The ZL1 hood for the 98+ body style was a custom job. None of the hoods that are marketed as the 98+ ZL1 hood even come CLOSE to the actual ZL1 hood.
The LT1 ZL1 hood = Rk Sport big block hood
You do mean the 2000 ZL1 Camaro right? If so I know which hood your talking about. It's the LT1 Big Block from RK sport only put on a 98+ style hood. If you look carefuly at that first hood posted here (the $1,000 on) it has the ripples on it that run from the head lights. But if you look at the real ZL1 as shown here:
http://community.webshots.com/photo/...0438qQSVcVyaWe
Those ripples aren't there. So it's the same as the big block from RK Sport I believe only black with the silver covering the scoop and it says 572.
I hope that makes sense lol... I hope I answered your question too.
Trevor
Trevor
Originally posted by 1996 | Z28 SS
Wasn't I agreeing with you?
I will try and find more photos of the 98+ bodystyle ZL1.. I have some rare ones..
Originally posted by pu12en12g
Once you see more photos of the 98+ bodystyle ZL1.. you can tell that it is a totally different shape than the RK Sport or DGM big block hood. I had the RK Sport hood, that is one reason I can easily tell the difference.
Of course...that's if you have an actual SS vin# as well.
