Blue00Z
04-30-2003, 05:40 PM
I have an ls1. Where can i put the big autometer sender for the oil pressure? Also where is the stock oil sending unit? I looked everywhere!! Thanks.
Autometer Oil Pressure gaugeBlue00Z 04-30-2003, 05:40 PM I have an ls1. Where can i put the big autometer sender for the oil pressure? Also where is the stock oil sending unit? I looked everywhere!! Thanks. 67 LS-1 & T-56 05-01-2003, 02:51 AM Hey howzit goin! Heres what you need to do: Look right above your oil filter, theres a small "fitting" (about 2 " long) with a neck on it . On the camaro engines this piece has no function. Your gonna take that piece off, (it has 2 bolts and a gasket) and drill and tap it for whatever threads you need. OR you can do what I did and buy the corvette LS1 piece from the GM dealer, which is already taped for metric threads, which should be eisier to tap for the autometer american threads. Hope this helps, Gordon Blue00Z 05-02-2003, 02:50 PM thanx | ||
