Smokn '94 Z 07-23-2002, 10:18 PM Well. Lets just say that I am pleased with the results. My best before the Hot Cam & FLP's was 13.61 @ 100.73 Today I ran 13.03 @ 105.67 I know the car will be quicker with Tires & cooler air. Race weight with me was 3695 lbs. My 60's were pretty good on street tires. 1.82 was the best 2.02 worst out of 5 runs. I really think with nittos I could see 12.7 to 12.9's easy. Thanks again to everyone with their input. I love my car again... http://web.camaross.com/bb/smile.gif Rt 66 Dragway......
Teal '94 Z Beefed up A4, , 3.73 Motive & Eaton Posi. -----------Best ET. 13.61 100.7 mph 1.86 60' on BFG Comp Ta's 17" Now I Just installed Hot Cam Kit, FLP's, A.I.R., EGR, TB Bypass, TPI's Aluminum Driveshaft, 52mm TB, Corsa, DMS springs, & PCM for less.
BigZ28 07-23-2002, 10:34 PM Nice times! Dump a little weight and get some traction and you will easily have 12.7's-12.9's. Skinnies are worth another .1. What converter are you running?
Brian
Smokn '94 Z 07-23-2002, 10:44 PM Just a 2000 stall........ I know if I get a Vig 3200 I could possibly see 12.5's . You think?
Teal '94 Z Beefed up A4, , 3.73 Motive & Eaton Posi. ----------- Hot Cam Kit, FLP's, A.I.R., EGR, TB Bypass, TPI's Aluminum Driveshaft, 52mm TB, Corsa, DMS springs, & PCM for less. New best on BFG Comp Ta's 17" tires.. 13.03 @105.67 1.82 60' race wt. 3695##
BigZ28 07-23-2002, 11:03 PM You definitely have quite a bit to gain with a higher stall conv. You could easily knock off .3-.5 with a Vig 3200.
Brian
[This message has been edited by BigZ28 (edited July 23, 2002).]
Smokn '94 Z 07-23-2002, 11:36 PM Here is a pic of a 13.06 run I ran beating the LS1 TA that ran 13.5 My runs in order were 13.07, 13.07, 13.06, 13.34 & 13.03 Pretty consistent.... 13.34 I spun hard out of the hole. http://web.camaross.com/bb/frown.gif http://www.tech-ls1.com/extras/RT66/pages/DSC00269.htm
Ken95Z28 07-24-2002, 08:33 AM Congrat's
If you do go to a higher stall, I good set of tires is needed. The LT4 HotCam loves the converter. You will be in the 12.5's for sure (traction permitted).
1995 Z28 A4 3.42 Best ET(12.205@109.50) LT4 Hot Cam, 1.6RR's, K&N FIPK, 85mm MAF, Mac Header & Y-pipe, Flowmaster Exhaust, CutOut, Yank ST3500, TransGo Shift Kit, LT1 ScanMaster, CSI WP, M/T ET Streets, 6-point Wolfecraft and Ed Wright Programming
Ken's 1995 Z28 (http://ken.lowrance.com)
F-Body Fastest List (http://www.oklahomaoutlawracing.com/FastList)
"Never be afraid to try something new. Remember that amateurs built the ark. Professionals built the Titanic."
Central PA Z 07-24-2002, 04:05 PM Congrats on the times. Your slip is exactly like mine after I installed the kit. If you haven't already.....you'll want to get that PCM reprogrammed. With just messing around with LT1 Edit and messing with my shift points, I am now at what's below in the sig. The only real difference in our cars is my suspension and I have a TCI converter, rates at around 3000 stall. You do have more in the car, just have to know where to find it. Good luck.
~John
1994 Z Car (http://camaroz28.cardomain.com/id/central_pa_z)
www.slfba.com (http://www.slfba.com)
The usual stuff on a set of Nittos and a dead posi.
60' = 1.920
1/8 = 8.368 @ 83.88
1/4 = 12.968 @ 108.04
Al Harrison 07-24-2002, 05:10 PM Nice times!I fave been playing with the idea of the hot cam since it is awesome deal for what you get.Also was going get TC at the same time.Now i have more the reason too.
On a side note does anybody know if SLP TC is any good.A vig or yank is to much $$ for me.Guys lt1 tech didnt respond to my post up there.
95 Z28 A4 blue with black racing strips
loudmouth exhaust,mac headers,az-speed marine 52mm tb and cold air intake,hypertech programmer,power pully's, msd ingition,eibach pro kit,hotchkis rear supension,hotchkis strut tower,performance spoiler,drag radails
Best ET 13.69
Best MPH 100.52
Smokn '94 Z 07-24-2002, 06:19 PM Thanks guys..... I have to now convince my wife to let me get a convertor. She said I was done!! http://web.camaross.com/bb/frown.gif I told here last night that it will be the icing on the cake & I will be done!!! Right... http://web.camaross.com/bb/wink.gif She hasn't bit yet.... http://web.camaross.com/bb/frown.gif Also I too can try to justify with my better half on this mod If I can get away with a cheaper priced convertor rather then shelling out twice as much for a vig or yank. Anything really wrong with going with TCI or something rather then the big 2? Maybe I'll post in tech too Thanks again everyone.
GJE94Z28 07-24-2002, 06:40 PM Congrats on your new times, she has alot more in her. With a higher stall, good tires, reprogram, decent air, you'll be in the mid 12's. I can relate with the wife thingy too...lol
94 A4 Black 3.42 gears
160 stat
CSI elec. water pump
LT1 edit
Hot cam
K&N CAI
March crank pully
K&N air foil
MAS port/polished
LT4KM
Edelbrock headers 1 5/8.
Crane Gold 1.6RR
Stock Coil
MSD 6A
Vigilante 2800
Transgo shift kit
Best 60ft: 1.76
1/8 ET: 8.15 @ 85.07
1/4 ET: 12.80@105.88MPH
T/A lt1 07-27-2002, 06:03 PM When I read your post I was like damn that is almost the exact et my car ran first pass with the hotcam kit and headers. I ran 13.01@106mph first pass but I have a little headwork and stock 3.23's. I then bolted on some ET streets and went 12.70 on the next pass with a 1.75 60'. I have a vig and love it. I know they are expensive but search the forsale and try to get a good used 2800-3000 vig and you won't be disappointed. I did some more tuning and got a 12.50@107mph the next weekend so you have alot more left in it. Because I think my car has some more in it with tuning then I am going to change the gears and start tuning the N2O.
1995 T/A RamAir,17x9 WS6 polished rims,A4 fresh, 3:23's,LT4 Hotcam kit, Ported heads and intake, built 355 with forged pistons, LT4KM,NX N20 kit 125-175hp, Custom programming, AS&M headers, Vigilante 2800,
flowmaster catback, Fernco intake bellow,CSI w/p,MSD 6al. New Et 12.50@107 N/A no nitrous times yet.
Smokn '94 Z 07-27-2002, 10:23 PM <font face="Verdana, Arial" size="2">Originally posted by T/A lt1:
</font>
Thanks for the Motivation!! http://web.camaross.com/bb/wink.gif I know I probably have 12's just the way it is. But I am salivating at the Idea of 3200 Stall. My new Dyno #'s are in the sig. I should be in the 12's with these #'s.
RWHP 324.5 / RWTQ 319.6 Dyno done by FLP
smacz28 07-28-2002, 03:38 AM Hey guys,
Have you thought about going with a Midwest stall? They have alot of the same internals as Vig and Yank for way cheaper. I had on built to my specs and shipped for $445 I believe. It was a great improvement. I just dynoed today and put down 270rwhp and 326TQ!!!! AND THOSE ARE DECLINING TORQUE NUMBERS AS PEAK WOULD HAVE OCCURRED B4 THE 3600 RPMS THE TEST STARTS AT. That is better than some of the hotcam tq I see in your guys sigs. I love my TC. Talk to John at HPA he is a straight shooter and tell him Shawn sent ya.
Shawn
