A3 users, what TC are you running?
Shon Herron
07-19-2002, 04:45 PM
And what lead you to that TC?
Old Setup was:
94 Z28 A4(3.73)
LT4 H/I/HOT cam
1.69/12.27@108
strokedTA
07-19-2002, 05:13 PM
COAN.
Steve Schmidt uses them. http://web.camaross.com/bb/wink.gif
I had my motor dynoed there and Coan used my dyno sheets to get me the perfect one.
TH400
If a little's good,
More is better,
And too much is just right!!!
rje
07-19-2002, 05:20 PM
Hughes soft hit 4000 TC. The guy I buy my custom grind cam suggested the size.
Randy
94Z 355 cid Hughes performance TH350 with 4000 TC, ported and polished 2.00, 1.57 valve heads, ported intake, 52mm TB, Bullet custom grind cam, Comp cams R series lifters, Hooker LT's, custom dual exh. with dynomax bullet mufflers,CSI elec. WP,MSD Digital 6+ ign,Autogage 5" monster tach with shiftlite,AC delete pulley, CC pro mag 1.6 rockers, Forged Ross pistons, 11:1 cr,B&M Pro stick shifter, eagle rods, polished stock crank,balanced rotating assembly , 24lb SVO injectors,Nitrousworks wet kit, AFPR, pcmforless custom program, alston SFCs, boxed LCAs with relocation brackets, tubular panhard rod,chassis engineering 8-point rollbar with 5-point harness, BMR Trac Pak, moser 12 bolt with 4.10's,1LE DS,Hurst line lock, eibach drag launch kit and airbag, HAL 12 way adj struts,CE 3-way adj. shocks, 15x3.5 front and 15x8 rear Weld Draglites with 27x11.5x15 Hossier QTP's. 1.607 60ft 7.62 @ 89.62 mph 1/8 12.02 @ 110.48 mph on motor.
1.55 60ft 7.16 @ 96.04 mph 11.27 @ 118.41 mph (125 shot) Shooting for 10's
In memory of the greatest
#3 Dale Earnhardt The Intimidator
KTamez
07-19-2002, 06:34 PM
Neal Chance Bolt-Together. I can change the stall myself for when I go NHRA S/ST racing (5500), and then change it back for some Headsup Spray action (4500). This along with a Complete 9" Center Section swap..... http://web.camaross.com/bb/smile.gif
Kurtis Tamez
LT4-396.com (http://www.lt4-396.com)
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body (http://www.teamnwfbody.org)
Wicked
07-19-2002, 10:10 PM
see sig.. Went with it because I was happy with the 3500 stall in my C5.
Jason
Plates: "Stock 95"
1995 Firebird Formula
O'ring/4bolt 383, GTP Race Ported AFR 210s, Yank TH400, Yank 3800 Stall, Trans Break, Moser 12 Bolt w/ 3.73s, and the usual stuff like Hooker Long Tubes, Holley 58mm TB, Sphon Torque Arm, etc....
chevyguy3
07-19-2002, 10:44 PM
Art Carr 9". should stall to ~4500 on the transbrake
onebad96T/A
07-20-2002, 11:12 PM
JW 9" 3500 converter
Why?
450$
And a 1 year warranty against any defects.
96 T/A 6" rod 355 c.i
Stage 3 heads and cam
A4p.o.s soon to be A3
And a little N.O.S
Looking for 10's
1fstTA
07-21-2002, 11:08 AM
i just installed my new ATI th400 and convertor, i went around to alot of the big races and just asked some of the fastest guys and the majority said ATI is the best. so i did some researching on them and liked what i found out.
95 ta m6 lunati 383,pro performance stage 2 heads, gtp cam, spec clutch, holley 52, strange 12 bolt, tnt n20, hooker 1 3/4 long, 3 inch exh flowmaster,
452.0rwhp and 416.5 rwtq
676.8rwhp and 842.8rwtq on n2o
Stephen 87 IROC
07-21-2002, 05:54 PM
JW 8". Currently stalls at 5000 with the transbrake. TH400, 4.56 gears, 29 x 9 tires.
Stephen's racing page (http://www.hardtail.com)
or check out the race car (http://www.hardtail.com/iroc.html)
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 116
Best corrected ET: 11.079
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.646
Member of the Calgary Drag Racing Association (http://www.calgarydragracing.ab.ca)
91rs383
07-22-2002, 07:16 PM
i am running a 3500 coan and am not happy at all with it. bought brand new last year $450 and would only stall around2500 and continually got worse as the season progressed. sent it back last winter and was told that some of the impeller blades were bent backwards and charged $180 dollars to get the same old 2500 (if im lucky) stall. on the other hand we have a 5500 coan in the 79 and couldnt be happier. ????????? has anyone else had this problem?
brandon
79 Z, 357, pro1 heads, victor jr.intake,
prostars, powerglide, 9" ford w/ 4.86 gear, etc...
best pass to date :10.16@132.72mph
91 rs stroked not sprayed
11.86@115 so far........
KTamez
07-22-2002, 07:29 PM
We've had a couple of Coan converters with good luck...
About the best of the best would be Neal Chance, and Continental.
Gotta broaden the horizons beyond all these guys running around here with Vig's and Yanks http://web.camaross.com/bb/wink.gif
Kurtis Tamez
97 Z28 LT4-396
94 Firehawk LT1-396
89ProchargedROC
07-23-2002, 02:38 AM
the neal chance converters have made a name for themselves in the NMRA
personally, when i order a converter it is going to be from midwest...they are within driving distance and if i dont like something i just take it to them and they fix it for me
my buddy has run one in his 9.0 nova w/o problems
BigRick
07-23-2002, 10:56 AM
Dynamic converter 5000 stall.
Brady
07-23-2002, 09:56 PM
I'm using a Precision converter. Why?: It was free. I ordered a 3500 stall when I was going to use the D-1X blower, but with these turbos it flashes to 5k+.. I'm going to the track Saturday for some testing but it looks like I'll be sending it back to get tightened up a bit.
...Brady
Twin Turbo 1996 Z28 (http://www.wheelhop.com)
Sponsored by YearOne (http://www.yearone.com)
'98 B4C Camaro (http://www.wheelhop.com/Camaro/REDLS1/RedLS1.htm) <--- FOR SALE
KTamez
07-23-2002, 11:15 PM
<font face="Verdana, Arial" size="2">Originally posted by Brady_96Z:
</font>
Sign me up for THAT plan! http://web.camaross.com/bb/biggrin.gif
Kurtis Tamez
97 Z28 LT4-396
94 Firehawk LT1-396
Joseph Overton
07-24-2002, 11:19 AM
ATI 8" 5500
Joseph Overton
94 TA (new combo new year)
old setup:381,.020 over,5.7 rod,afr heads,comp cam,custom intake,1200 cfm tb,42# inj.,aeromotive pump,DFI,dry nos,th400,strange 12bolt,wolfe rollcage,subframes,lca,s
best n/a 10.95@124.06 1.55 60 ft.
best n20(65 jet) 10.28@128.8 1.43 60ft.bent torque arm on launch
[This message has been edited by Joseph Overton (edited July 24, 2002).]
