phil94-T/A
04-23-2003, 09:43 PM
I have a welder....I have some subframes....now the question I have is can I install the subframes with the car up on jackstands?
The jackstands will be positioned under the rear end, and under each A-arm. Is it feasible????????
Thanx
PHIL:confused:
SBainsTA
04-23-2003, 10:11 PM
I beileve so. Just watch out for the fuel lines on the drivers side when welding
CoryM
04-23-2003, 10:14 PM
Sure can... If you dont mind getting sparks in your face. you could also borrow some ramps for the front. Those steel car ramps are known to collapse BTW. I dont use them. The solid rubber or plastic ones are supposed to be pretty good though.
Personally I wouldnt bother straightening the chassis before doing SFC (unless you want things to be perfect) as the unibody will still twist and flex a little even with the SFC. I would however get the unibody straight before doing a cage.
Good Luck.
CoryM
JD30thZ28
04-23-2003, 10:24 PM
As mentioned won't be a problem it will be level enough.
Watch out for the fuel lines ;)
sleeperZragtop
04-23-2003, 11:03 PM
Hey Phil...I could help...and do mine at the same time:D
mr_muff
04-24-2003, 01:20 AM
i should buy some and then we can all do it at once, im sure one of us would be able to get a lift for a couple hours. it is a fairly easy job is it not if we could get a lift?
oh yea i forgot i have no money :/
can we wait a month and a half
hehe j/king
