crank hub bolt stuck in crank
Old Apr 22, 2003 | 07:40 PM
95 firechicken's Avatar
i'm in the middle of doing a heads/cam swap and just about done when i go to tourqe the crank hub bolt back on i feel it give and now i can't get the bolt to go in or come out please help i've tried everything with no luck
Old Apr 22, 2003 | 07:56 PM
Sounds like you could have a big problem.
You need to find a way to pull outward on the bolt as you try to unscrew it.
Old Apr 22, 2003 | 08:36 PM
I burn rice too's Avatar
Go get an extractor. All you gotta do is driill into the broken bolt and insert the extractor, I use them alot at work. Just make sure that you use the right drill bitt. Good luck.
Old Apr 22, 2003 | 09:05 PM
iv'e tried ez-out's fluted and spirals no luck
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
cyteone
Feb 7, 2015 06:04 PM
