M6 is making noise, help!
Old Apr 22, 2003 | 02:22 PM
JDMZ28's Avatar
I just noticed I sometimes have trouble dropping my car into first from a roll, sometimes it grinds but not all the time.
Today while driving I noticed if I leave the shifter in gear and push the clutch in I hear vibration/gears coming from the trans. It sounds like a somethings out of balance. You guys have any idea?
Old Apr 22, 2003 | 02:34 PM
hsyr's Avatar
Sounds like the master/slave is crapping out. Check that out.
Old Apr 22, 2003 | 02:38 PM
JDMZ28's Avatar
how do I check it?
Old Apr 22, 2003 | 04:09 PM
hsyr's Avatar
Unbolt the slave from the tranny (2 1/2" nuts). Route it up to the drivers side of the motor. Take the cap off the resivoir(sp?) for the fluid. Then pump the slave and see if any air comes out of it. If some comes out that might help. If not, push the slave all the way in with your hand and have someone push the clutch pedal in. If the end of the slave comes all the way out then its fine, but if its stopping halfway and you need to pump the clutch pedal for it to come out all the way then it needs replacing. I ordered a new slave cylinder for my 94 today and all it costed me was $81 canadian Good luck.
Old Apr 22, 2003 | 04:21 PM
JDMZ28's Avatar
I just took it for a ride, no noise when clutch was disengaged. Although it still did not like going into first gear and I noticed a little whine when the shifter moved into the next gear.
warmeck
Mar 22, 2015 10:28 AM
Fatdog2
Feb 12, 2015 12:24 PM
warmeck
Feb 5, 2015 11:04 AM
jcamaro95lt1
Jan 24, 2015 08:21 AM
squarehead
Nov 21, 2014 08:02 PM
