2_shady
04-20-2003, 12:46 AM
I put in some leds last night and they seemed to work fine for the most part... except when i did the steering wheel controls i had to strecth the wire in order the pull it out far enough to disconnect it.. well when i went to leave last night my wheel started makin a noise when i turned it.. sounded like something was out of place/rubbing.. well about 2 min later my air bag light stuck on....
this morning i took it all apart.. the air bag fuse is fine.. and all of the connections from under the dash all the way to the actual air bag are tight... the only think i couldnt do was take off the steering wheel since i dont have a puller... well when i put it all back together the light would flash about 6 times or so before being constant.. i can not figure out what is wrong.. something is obviously out of place since its making the noise, but all the air bag wires seem fine..... so now i took out the fuse, and disconnected the air bag just to be sure it doesnt randomly blow.... anyone have any clue on what it could be?
thanks
jay
thanks
jay
